Please Help $900 budget build
I need help build a computer for my bro and I, well be using the same build. I live in the U.S and have around $900 budget for each build. For perfered retailer I only care that I have a AMD graphic card because of mantle. When it comes peripherals we don't need them, but we want a gaming mouse and keyboard. We'd like black or red cherry mx switches and the mouse we want it to be made for all genre games. I've been looking at this mouse: http://www.amazon.com/Logitech-Wireless-Gaming-Mouse-Battery/dp/B00E4MQODC
We'll be using it for gaming mostly, with web surfing. We play A LOT of MMORPG, with a little of most other genres of games. I would like to play games on at least 60fps at 1080p. I would it if the mouse is capable of button management for most genre of games and I don't care if the keyboard has macros. I just want the pc to be a powerful gaming pc.
The only games I know that I will be playing that should be at all worried about is Skyrim, and Battlefield 4
I would like to get into over clocking if possible, I don't want to do anything water cool since it's my first build, and I need a OS if y'all think I need. I currently have windows vista 32 bit.
http://pcpartpicker.com/p/23buJ
Thanks for the help :)
How old is your current pc because maybe you could salvage some parts from that pc andwith the money you save you could buy a much stronger pc because if you wanted to spend 900 bucks on only the PC (no periferals or OS) you could get a so much stronger pc. You probably can salvage your harddrive from your old pc.
http://pcpartpicker.com/p/23fov this is a nice build if you already have an HDD and it is more powerfull then the build above because of the grafics card. Do notice however that the powersupply which is in the build has an promocode that only runs until next monday after that the PSU will be the same price as the xfx.
I have windows vista 32 bit and i have a hard drive thats not that old i have a mouse and keyboard .....http://reviews.cnet.com/desktops/emachines-w3629-p4-631/4505-3118_7-32813250.html
my curent pc but with a better mouse keyboard and hard drive
What about this.. do you think theirs any thing you  can do to make it better
PCPartPicker part list: http://pcpartpicker.com/p/23mPs
http://pcpartpicker.com/p/23vTw
Better PSU(rebranded Seasonic, I have it in my own system, JonnyGuru Recommended), better motherboard(multiple GPU support).  And the RAM you chose is back to 80 bucks(insane :P), and the MoBo you chose is out of stock at newegg.
PCPartPicker part list: http://pcpartpicker.com/p/23ENN
I think i got it......
Eh, CPU has old architecture and motherboard has a relatively weak 4+1 power phase design that won't hold up very long to the power hungry 8 core CPU.
http://pcpartpicker.com/p/23UGs
CPU has newer architecture, Mobo has much better power delivery, RAM is actually in stock at that price, Hitachi is a relatively unreliable brand so I went with Seagate, GPU is a steal at that price(if you can pick it up when it comes back in stock).
