I was playing Fallout 4, my pc like fuck you. Shut off. I turned it back on, said I was missing 3 files on W7. Possible, pirated it years ago and never updated it. Okay so my PC is fucking bricked at this point. I never made any images or mirrors or whatever to boot from in the event of this. Now I figured this should mean my hardware is okay.. maybe.. hopefully. I hoped enough that I bought a windows 10 copy. Nowww, I've only ever installed OS's through a disc. Now here's another fuckin sideswipe in my operation. My motherboard, ASUS 970 LE 2.0. It only fucking shows half my screen in bios and my pc is being a PROVERBIAL FUCKING CUNT and sitting at the Press F2 to fuck yourself or whatever screen for like 30 minutes before I can do shit so it's really not the easiest to enter my bios.
So if anyone has any life tips or pc assistance they could lay onto me it'd be very very nice because I mean I've been fuckin with PC's forever man but this is just some otha shit I'll tell u hwwat
So do you have any access to any other computers? You can download Microsoft media creation kit and install Windoes 10 to a USB then do an upgrade from there. As far as the activation goes. I suppose you can leave it like that for now until you feel that you can get an activated copy down the road. With luck, the Windows 10 upgrade will retain your data.
Fuck the half screen thing for now. Def my GPU having sub par drivers. My current situation is;
I'm at my boot menu all my options are is the DVD drive and my hard drive. I need to boot it from the flash to install Windows 10, bc my current windows 7 is fucked
I bought it from a PC shop for 60 bucks few years back. When I reinstalled it to clean my pc I couldn't reuse my code they gave me though.. My PC WILL start(ish) it just goes to a plain black screen in which I can move my mouse about
The only thing I can advise you to do is use the Windows installation disc and try to repair Windows. that's all you can really do at this point. repairing the system shouldn't require the key if my memory serves me right.
I can't repair it because I never made a backup image or whatever, that's why I spent 130 bucks on windows 10. Now it don't work. Finna cry in this bitch
you're welcome. I don't know what else to tell you. if Windows is acting up, without that disc you're boned. it's sort of the reason all that "repair stuff and all that" has been built into Windows since Windows 8. though what was dumb was you still needed the disc. now with Windows 10 you don't.
I had the disc for 4+ years it was so scratched i doubt it even ran properly. plus it had no writing on it. i might still have it. Shit idk. this is where it leaves me when i sit through it. It's some bullshit i can't boot from the 10 flashdrive tho... could i put it on a disc and boot from it? <img src="/uploads/default/original/3X/5/9/59524912d36c552499821b164a4f05aeff90acd6.jpg" width="720" height="540"
