Please fix this build
I need someone to find me a better PSU and Mobo for this build: The PSU prices are KILLING me. https://pcpartpicker.com/list/WtBTDx
https://pcpartpicker.com/product/7v3mP6/seasonic-focus-850-w-80-gold-certified-fully-modular-atx-power-supply-focus-gx-850
https://pcpartpicker.com/list/G2xRRk
Is the Fury X RAM better than the GSkill FlareX? the FlareX Kit is quite a bit less expensive for the same quantity. Also, can you recommend a good case alternative? No Corsair or NZXT Please.
For cases i would refer to Gamers Nexus.
Phanteks P400A and the Meshify C are good options (and cheaper), only check if your cooler fits :slight_smile:
yeah. Im planning on keeping my NH-D15S if Noctua gives me (or has) a AM4 mounting kit for it
