Also, try not to get jealous of my astonishing paint skills.
whats your budget if your willing to spend that much on a pc you should be able to afford a better GPU
Using the 980 from my tower. Upgrading that one... so technically not buying that graphics card. Just showing for reference.
its not to bad then but i would get a better PSU the cx ones arent the best quality
Agreed. Was originally thinking HXi 750i, but I'm afraid there are clearance issues. Could you recommend something?
PSU bay is 180mm deep. Figured I could get away with around 160-165mm for cable routing
http://www.corsair.com/en/rm-series-rm650-80-plus-gold-certified-power-supply look at this one fully mod and i dont think you need 750W for a 980 and a i7 4790k
I'd rather play it safe with a 750w+ because I plan on overclocking the hell out of both the CPU and GPU, seeing as how I'm spending the money on the custom WC loop. Plus my microphone, keyboard, and mouse are fairly power hungry. I prefer Corsair, because I've never had a problem with any PSU I've had from them, but by no means does that mean I wouldn't consider a different brand. Just don't know anything about other brands.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139042 would work?
Was more worried about the WC side of things. Got the hardware game locked down. Not my first rodeo; just my first water-cooled rodeo.
