Playing games with no graphics card?
Is it possible to play a game with no graphics card and only using on board graphics. How would you do it?
Thanks
Well it depends what CPU you have. If your CPU has integrated graphics you'd just plug your monitor to the display connector on the motherboard. You could then play your game.
That being said AMD FX and the Athlon line as well as Intel Xeons don't have iGPUs. You'll need one to have any display at all.
The higher end AMD APUs can do a good job on integrated graphics at 720p but nothing extreme.
Intel's iGPUs, other than the Iris Pros, are pathetic and you won't be playing games on those.
yes and you would install games like you normally would.  What on board are you using as it may be under powered for games.
I see you have an AMD A8. You could play some games on that. You will prob have to turn the settings all the way down and run at 720p but you'd be able to do it.
For my personal experience, i play GW2 on my MacBook Pro when i traveling and it use the HD3000 gpu integrated in the i5 Intel cpu. Low quality, but still playable (not the WWW part, no at all)
