Hi, I'm planning to build a pc (probably on December) with a budget of A$800 (Australian dollar) - and will be first time building one and mostly use it for MMORPG games like tera and Aion and steam games. I would prefer it to be not less than 30 fps and a reasonable graphic settings. Other than that, I think I would prefer to use the AMD FX-8350 CPU (but open to suggestion). For OS, Windows 8.
It is possible to game on one, that's why I upped the RAM to 2133MHz, to increase the graphics clock on the GPU portion of the APU, or I could've gone the route of adding a Radeon HD 6670 for a hybrid crossfire config, but that would've been annoying for games that aren't configured for crossfire support.
Otherwise that's a decent build you've put together.
I see, well this is quite off my budget but, is it ok? http://au.pcpartpicker.com/p/1LIg9 <-- or any better suggestion? I cant go more than $877 though (guess I'll buy a cheap keyboard XD) (the ram I can always upgrade in future)
