Planning on building a pc
So im going to be building my first pc. Now to start off im going for something cheap.
So one of these two.
http://www.youtube.com/watch?v=s6kFRalEq-M
http://teksyndicate.com/videos/build-best-350-gaming-pc-nov-dec-2012
My question is which one would be better for gaming? And do I need a graphics card? I am new, but neither of them seem to have one.
Thanks for helping guys!
Try this ram. It has a fast cas latency that is perfect for gaming.
G. Skill Ripjaws X 8GB (2x4) DDR3 1600 Cas Latency 9
http://bit.ly/TFIYSS
You didn't really answer my question... But now I have another one, is this case compatible with the 350 build
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Okay to answer your question the second one is miles ahead of the first link. The reason is because of the new FM2 APUs from amd. Yes, that case is compatable with the build that teksyndicate did. One quick thing to check is the form factor of the motherboard which in this case is "ATX" that case supports atx mobos. So, your good man. Like logan says in the video the speed of your ram directly affects gaming performance because the APU uses system memory for video memory. The faster the memory the more frames you get in games.
Thanks man really helps, planning on building this soon
