so i recently upgraded my mobo to this Asus board (http://www.newegg.com/Product/Product.aspx?Item=13-131-876) which has 6 sata iii ports, and i was thinking of using 6 drives however i also want those drives in raid.
My plan was to have 2 256gb SSDs(http://www.newegg.com/Product/Product.aspx?Item=N82E16820227792) in Raid 0 for my OS, Games, and often used programs
Then i would also have 4 2tb HDDs(http://www.newegg.com/Product/Product.aspx?Item=N82E16822148910) in Raid 10 for media and backing up the Raid 0 array
Now the problem i face is that i dont want all the raid load put onto the onboard raid controller. (not sure if it can handle it)
So my questions are:
Could my onboard raid handle the array?
if i need a raid card, Would it be better to put my 4 HHDs or my 2 SSDs on the raid card?
And continuing, Do u guys have any suggestions for which raid card to get that is:
1. Under $350 (usd)
2. Has at least, 1 SAS (either for putting all drives or less on the raid card), 2 SATA iii (for using the the Raid card to raid the SSDs), or 4 SATA ii internal ports (for raiding the 4 HDDS together)
3. can use a slot that isnt taken up by a PCIe dual slot graphics card
----end of questions---
feel free to leave other suggestion for setting up the drives (keeping cost including raid card and drives under $1000), any help is appreciated
PS (add ins)
the links are to newegg, however i will use pcpartpicker and get them from the cheapest source that i trust
now thinking of skipping 6 drives in array and just have this idea:
4 SSDs in Raid 10 for OS, games, and
and 1 2tb drive for media and such, however im still looking at options
Continueing with the 6 drive idea i am looking at 4 SSDs and 2 3tb HDDs for my drives the SSDs would be in RAID 0 and the HDDs would each be lone drives one for backups and one for media
