Planned Gaming PC build
I am planning to build a Gaming pc. Im extremely new to this kind of stuff, so I need to know if these things are good:
PCPartPicker: http://pcpartpicker.com/user/xxslainmagicxx/saved/29pH
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor
Motherboard: Asus Maximus VI Hero ATX LGA1150 Motherboard
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2133 Memory
Storage: Western Digital Caviar Black 2TB 3.5" 7200RPM Internal Hard Drive
GPU: Gigabyte GeForce GTX 770 2GB Video Card
Case: Fractal Design Core 3000 USB 3.0 (Black) ATX Mid Tower Case
Power Supply: Corsair CX 600W 80 PLUS Bronze Certified ATX12V Power Supply
Dvd Drive: LG GH24NS95 DVD/CD Writer
Some Info:
My budget is £1000. I believe this build is around £850-900.
I hope to run Minecraft max settings no problem... But thats easy, I can do that now, and know this will be able to.Some info:
I would like to be able to max every single game at the current time, and for a few years to come.
My currency is £, but $ is fine fyi.
I do youtube, so being able to render would be nice, but not needed.
I dont have ANY of the stuff yet, so I need to save up for quite some time. It is possible that i wont have the money until mid to late next year. Hopefully that doesnt confuse things, but thing may change then.
Im not sure if anything else is needed, but I simply just need to know if this is a good rig, and if it will be easy for a first build... Im kind of scared about building my first rig, but im sure it will ok.
-Alex
Looks good!  Only things I would change are:
CPU: i5 4670k is great for gaming.  An i7 is overkill, but may help a little bit in video editing ajd 3D modeling.
RAM: 8Gb is more than enough for gaming, and getting some cheaper 1600mhz will help you save money as the main reason to get higher clocked ram is for an iGPU, which you are not using.  Use the money on:
SSD: Get a 60-128GB SSD for your operating system and commonly used programs.
GPU: GTX 780, if possible.  I'd get a better gpu and an i5.
Is this better?
http://pcpartpicker.com/p/1JJzL
Btw, im happy to have 16Gb. Incase i want to upgrade or something
Looks pretty damn good to me.
Thanks bro. Now to save up for it D:
