Hello there,
I just registered on this site. Because i'm looking for some Help and Feedback about my Build,
I am planning to get this Components:
Cooler Master K-380 Advanced 3.0
600 Watt Cooler Master
ASRock 970 Extreme4
7.1 Soundcard
Crucial Ballistix Tactical 8GB DDR3-1600
1000 GB SataIII Harddrive
Nvidia GTX 760 2GB
Just wondering if i am doing good with this build, This is the first time i'm building a computer myself, and i'm wondering what FPS i'll pull on the Next-Gen Games and such.
Greetings, Zorthac
Welcome to the Forum first of all ☺
my first question to you is what is your budget? because i dont realy get a clue about the components you posted.
i would recommend to use partpicker to setup your build its easier for your self, and for others.
http://pcpartpicker.com/
Grtz Angel ☺
Hey there,Thanks a lot and Thanks for the quick reply : )
Here is the link of Pcparts http://pcpartpicker.com/p/1JFV5
Sadly enough, I couldnt find the case on there. But here is another link to my case. ( Not the Excact case though, I'm using the K380 Advanced 3.0)
http://www.coolermaster.com/product/Detail/case/mid-tower/k380.html
Hope this is better : )
And btw, i'm using European Currency.
Greetings Zorthac
Not bad for a first. Some advice:
CPU: FX-6300. Save some money as you spent too much on the CPU
GPU: HD 7950. It'll outperform the 760 and is pretty cheap.
PSU: Missing! Get an XFX PRO550W psu. It's a rebranded Seasonic, one of the best psu makers out there.
Well your build looks good, i would say stay with the FX8350, its a very sollid and future proof cpu.
The only thing i would personaly change is the Hardrive, pickup a WD caviar blue 1TB. for the same price.
GTX760 is a good gpu, but you could also look into a Radeon 7950 for example the Asus 7950 direct CU ii if you overclock this card it will compete straight up with an oc GTX770, but its alot cheaper. even cheaper then the GTX760.
psu an XFX 550W or 650W is a good choice.
Thanks for the replies : )
About the GPU, I really want to stick with Nvidia.
And my PSU, I only can choose between Power Supplies from Cooler master, since i'm making someone build a PC for me. Because i'm too scared to build it myself.
Eventhough people say it's so easy, and all the guides on internet. i'd like someone else to buy it, who knows what he is doing.
But i will slowly learn it myself, once i upgrade my computer : )
I learned through google and a used computer I bought for cheap.
Upgrading components is a great first step. I ended up both rebuilding and rewiring my old computer, and selling it for a profit. Forums, Google, and Youtube are great for learning. If you can watch your friend build your computer, it'll be really beneficial.
