Not on my PC. Unless you gave unloaded a replacement copy with corrected audio, the audio L/R channels are correct on my PC.
@wendell, Recent Nvidia graphics cards have a sync technology that is monitor independent called Fastsync that I would recommend over vsync. It uses the graphics card vRAM frame buffer to manage the frames that are sent to the monitor at its native refresh rate and has much lower latency than vsync.
I believe that it will work either stand alone or in tandem with G-sync monitors
WOO! New opening music. Much appreciated. I was getting really irritated by the odd drum stumbling at the start you usually use. I as seriously tempted to remake that song and fix the start is annoyed me that much.
So thank you.
Also nice review, I want something like this but I am also tempted to just get another 2 ipad screen and make it a triple wide. For that though I need new everything, I would need more DP to make that even half work and then it is a lot of pixels to drive.
