I play counter strike global offensive and burn DL dvd's that is the "difficult" things my computer will be doing. I will be buying a processor, mobo and ram.
Reusing the following parts:
Lian Li Case (Full Tower) - Antec NEO ECO 520c - Nvidia 650ti 1gb - iHAS Burner - Hard Drive(s)
Maximum Price for the upgrades should be ~$350
A10-7850k Build http://pcpartpicker.com/user/nobutada55/saved/3E6S
FX-8350 Build http://pcpartpicker.com/user/nobutada55/saved/3E7a
FX-8320 Build http://pcpartpicker.com/user/nobutada55/saved/3FqB
i5 4670k Build http://pcpartpicker.com/user/nobutada55/saved/3E7g
If I am missing anything that might not work with my old gear PLEASE tell me.
Thanks in Advance!
well for the FX8350 and the FX8320 i would realy recommend a better motherboard. Asus M5A99FX Pro R2.0 for example.
Those cheap Asrock 970 boards with only 4+1 powerphase and analog vrms are not realy designed for a powerhungry 8 core cpu.
That being said, i would also recommend to get 2x4GB instead of 1x8 unless you plan on upgrading 16GB.. because those cpu´s have dual chanel memory controllers.
First off, I'd switch the 1x8GB for 2x4GB. The dual channel will give you more performance.
I immediately ruled out the APU build since you have a GPU already, and I'd definitely go for one of the FX builds over the 4670k as they're cheaper and will often perform better in many tasks. You could always overclock the 8320 to get 8350 speeds if you want.
So my vote goes to the 8320 build with the different RAM
Edit: Also what MisteryAngel about the motherboard.
The i5-4670K is also not a bad choice for gaming, but same story about the motherboard, in terms of overclockability and feutures, that msi G41 board is not that great. ☺
if you dont care about overclocking, then just a i5-4670 with a H87 or B85 chipsetboard will also do well for gaming. like the Asrock B85 killer mobo. that Wendell recently reviewd.
How about I get a fx8320 + GA-990FXA-UD3 + Crucial Ballistic Sport 8gb DDR3-1600(2x4GB) +EVO 212 Cooler?
$361.21 and I can pick it all up at Microcenter.
