Pick It Apart - My First Gaming Build
So I've been wanting to build my own PC for some time now, but I haven't due to work and life conditions. I'm currently using my Asus u30JC-A1 laptop that I got as a gift back in college. It works great and I love the thing, but gaming wise, it was a mid-range at best when it was new. Now, it barely keeps up with current-gen games, even with the 8gb of ram I shoved in there. With the next-gen games coming out, I only see myself falling further behind.
That is how I built this rig, so I won't be behind. I wanted to essentially play the upcoming Star Citizen on max with decent frames. I also wanted to leave enough upgrade-ability to keep up with whatever is coming down the pipe in the future.
Here is the UPDATED link to my part list, and please let me know what you think: http://pcpartpicker.com/user/SilkyZ/saved/2KR1
The list includes a fair number of extra parts to that makes the price fairly high on the sheet's total. The system itself is about $1400ish last I remembered
Do the Prodigy Custom Front Panels from the old Prodigy fit on the new M?
See, I would imagine they would as it's basicly the same box. But if not, it not a game changer
1. If you're not going to be overclocking like hell,a CM 212 EVO would suffice
2.8gb of RAM is enough for gaming.If you are into content creation as well,then more would be better.Otherwise 8gb would do fine.
3.Use the money saved from either above and get a better GPU.Not that i'm implying the 280x is terrible.Better GPU for the same-ish money
Altered your build slightly with what i mentioned
http://pcpartpicker.com/p/201k9
Hey, thanks for updating the my list, I was debating on the 16 or 8 GB for a while and I went high just because.
I'll update it with a better GPU then. Thanks again
