If you’ve got nothing important on it you may as well. I’m not sure what the PIA scripts do so i’m not where where they may have made changed. Assuming its the changes that cased the issue.
If you do id recommend just manually adding a ovpn config rather than the scripts, get it working first, plus you’ll know exactly whats changed where.
You could try fixing you current install, but i probably wouldnt be much help, bit blend to the raspbian setup.
Is there a script I could make where I can change the location when I want to, right now it is set to US East
would be nice to move it when there is problems or for easy browsing
Was think of a script that would stop the vpn change the location then start the vpn. Problem is my knowledge of linux commands is very very small. Did use google to search did not get any useful info for my knowledge level back.
That way I could make the few that i need place them in a folder and it would be good enough for what I need.
Just added the line to the bottom of each new location
auth-user-pass login.conf
this is an example of one of the locations
client
dev tun
proto udp
remote us-midwest.privateinternetaccess.com 1198
resolv-retry infinite
nobind
persist-key
persist-tun
cipher aes-128-cbc
auth sha1
tls-client
remote-cert-tls server
