Did the instructins here on this page and got this message in terminal
pia-nm.sh: line 162: uuidgen: command not found
Installation is complete!
And when I click on the arrow up and arrow down I only get wifi on and wifi off there is not info for lan line
Lan line is working cuz that is what I am using to type this now.
When I am on my Manjaro pc It shows more info on the up down arrows
pi@raspberrypi:~ $ sudo bash pia-nm.sh
PIA username (pNNNNNNN): p4046375
Connection method (UDP/tcp):
Strong encryption (Y/n):
Your missing uuidgen, you likely need uuid-runtime installed. (for whatever reasons apt doesnât have a provides command, but thatâs the package I found)
Do you really need pia client working, if I recall most of these are just wrapped OpenVPN clients you should be able to grab the config and modify it for your needs.
On manjaro I did a manual setup of the Openvpn.
With the new offerings of a, what looked like an easy install, was hoping this would be faster and easier to get done.
Doing the setup myself there is some limitations, you have to setup each new vpn location separately.
Just not that good with linux.
If anyone has some suggestion on how to make the PIA install work that would be great.
Thanks for the help
When I did the restart on the network manager I got this message
pi@raspberrypi:~ $ sudo service network-manager restart
Job for NetworkManager.service failed because the control process exited with error code.
See âsystemctl status NetworkManager.serviceâ and âjournalctl -xeâ for details.
pi@raspberrypi:~ $ sudo systemctl
UNIT LOAD ACTIVE SUB DESCRIPTION
proc-sys-fs-binfmt_misc.automount loaded active waiting Arbitrary Executable
sys-devices-platform-soc-3f201000.serial-tty-ttyAMA0-hci0.device loaded active
sys-devices-platform-soc-3f201000.serial-tty-ttyAMA0.device loaded active plug
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mm
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0.de
sys-devices-platform-soc-3f300000.mmc-mmc_host-mmc1-mmc1:0001-mmc1:0001:1-net-
sys-devices-platform-soc-3f980000.usb-usb1-1\x2d1-1\x2d1.1-1\x2d1.1:1.0-net-et
sys-devices-platform-soc-3f980000.usb-usb1-1\x2d1-1\x2d1.4-1\x2d1.4:1.0-sound-
sys-devices-platform-soc-soc:audio-bcm2835_alsa-sound-card0.device loaded acti
sys-devices-virtual-block-ram0.device loaded active plugged /sys/devices/vir
sys-devices-virtual-block-ram1.device loaded active plugged /sys/devices/vir
sys-devices-virtual-block-ram10.device loaded active plugged /sys/devices/vi
sys-devices-virtual-block-ram11.device loaded active plugged /sys/devices/vi
sys-devices-virtual-block-ram12.device loaded active plugged /sys/devices/vi
sys-devices-virtual-block-ram13.device loaded active plugged /sys/devices/vi
sys-devices-virtual-block-ram14.device loaded active plugged /sys/devices/vi
sys-devices-virtual-block-ram15.device loaded active plugged /sys/devices/vi
sys-devices-virtual-block-ram2.device loaded active plugged /sys/devices/vir
lines 1-23
proc-sys-fs-binfmt_misc.automount loaded active waiting Arbitrary Executable File Formats File System Automount P
sys-devices-platform-soc-3f201000.serial-tty-ttyAMA0-hci0.device loaded active plugged /sys/devices/platform/soc/
sys-devices-platform-soc-3f201000.serial-tty-ttyAMA0.device loaded active plugged /sys/devices/platform/soc/3f201
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p1.device loaded active plugged
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p2.device loaded active plugged
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p5.device loaded active plugged
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p6.device loaded active plugged
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p7.device loaded active plugged
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0.device loaded active plugged /sys/dev
sys-devices-platform-soc-3f300000.mmc-mmc_host-mmc1-mmc1:0001-mmc1:0001:1-net-wlan0.device loaded active plugged
sys-devices-platform-soc-3f980000.usb-usb1-1\x2d1-1\x2d1.1-1\x2d1.1:1.0-net-eth0.device loaded active plugged SMS
sys-devices-platform-soc-3f980000.usb-usb1-1\x2d1-1\x2d1.4-1\x2d1.4:1.0-sound-card1.device loaded active plugged
sys-devices-platform-soc-soc:audio-bcm2835_alsa-sound-card0.device loaded active plugged /sys/devices/platform/so
sys-devices-virtual-block-ram0.device loaded active plugged /sys/devices/virtual/block/ram0
sys-devices-virtual-block-ram1.device loaded active plugged /sys/devices/virtual/block/ram1
sys-devices-virtual-block-ram10.device loaded active plugged /sys/devices/virtual/block/ram10
sys-devices-virtual-block-ram11.device loaded active plugged /sys/devices/virtual/block/ram11
sys-devices-virtual-block-ram12.device loaded active plugged /sys/devices/virtual/block/ram12
sys-devices-virtual-block-ram13.device loaded active plugged /sys/devices/virtual/block/ram13
sys-devices-virtual-block-ram14.device loaded active plugged /sys/devices/virtual/block/ram14
sys-devices-virtual-block-ram15.device loaded active plugged /sys/devices/virtual/block/ram15
sys-devices-virtual-block-ram2.device loaded active plugged /sys/devices/virtual/block/ram2
lines 1-23
proc-sys-fs-binfmt_misc.automount loaded active waiting Arbitrary Executable File Formats File System Automount Point
sys-devices-platform-soc-3f201000.serial-tty-ttyAMA0-hci0.device loaded active plugged /sys/devices/platform/soc/3f201000.serial/tty/
sys-devices-platform-soc-3f201000.serial-tty-ttyAMA0.device loaded active plugged /sys/devices/platform/soc/3f201000.serial/tty/ttyAM
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p1.device loaded active plugged /sys/devices/platf
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p2.device loaded active plugged /sys/devices/platf
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p5.device loaded active plugged /sys/devices/platf
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p6.device loaded active plugged /sys/devices/platf
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p7.device loaded active plugged /sys/devices/platf
sys-devices-platform-soc-3f202000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0.device loaded active plugged /sys/devices/platform/soc/3f
sys-devices-platform-soc-3f300000.mmc-mmc_host-mmc1-mmc1:0001-mmc1:0001:1-net-wlan0.device loaded active plugged /sys/devices/platfor
sys-devices-platform-soc-3f980000.usb-usb1-1\x2d1-1\x2d1.1-1\x2d1.1:1.0-net-eth0.device loaded active plugged SMSC9512/9514 Fast Ethe
sys-devices-platform-soc-3f980000.usb-usb1-1\x2d1-1\x2d1.4-1\x2d1.4:1.0-sound-card1.device loaded active plugged Headset H390
sys-devices-platform-soc-soc:audio-bcm2835_alsa-sound-card0.device loaded active plugged /sys/devices/platform/soc/soc:audio/bcm2835_
lines 1-23
Aug 05 01:18:42 raspberrypi systemd[1]: Failed to start Network Manager.
Aug 05 01:18:42 raspberrypi systemd[1]: NetworkManager.service: Unit entered failed state.
Aug 05 01:18:42 raspberrypi systemd[1]: NetworkManager.service: Failed with result âexit-codeâ.
Aug 05 01:18:42 raspberrypi systemd[1]: NetworkManager.service: Service hold-off time over, scheduling restart.
Aug 05 01:18:42 raspberrypi systemd[1]: Stopped Network Manager.
Aug 05 01:18:42 raspberrypi systemd[1]: NetworkManager.service: Start request repeated too quickly.
â Unit NetworkManager.service has finished shutting down.
â Subject: Unit NetworkManager.service has failed
â Defined-By: systemd
â Support: https://www.debian.org/support
â Unit NetworkManager.service has failed.
â The result is failed.
Aug 05 01:25:29 raspberrypi sudo[6095]: pi : TTY=unknown ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/rc_gui
Aug 05 01:25:29 raspberrypi sudo[6095]: pam_unix(sudo:session): session opened for user root by (uid=0)
Aug 05 01:26:20 raspberrypi sudo[6095]: pam_unix(sudo:session): session closed for user root
Aug 05 01:40:00 raspberrypi sudo[6433]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/leafpad systemctl status
Aug 05 01:40:00 raspberrypi sudo[6433]: pam_unix(sudo:session): session opened for user root by (uid=0)
Aug 05 01:40:08 raspberrypi sudo[6433]: pam_unix(sudo:session): session closed for user root
Aug 05 01:43:03 raspberrypi sudo[6468]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/systemctl
Aug 05 01:43:03 raspberrypi sudo[6468]: pam_unix(sudo:session): session opened for user root by (uid=0)
Aug 05 01:45:27 raspberrypi sudo[6468]: pam_unix(sudo:session): session closed for user root
Aug 05 01:45:39 raspberrypi sudo[6508]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/systemctl status NetworkManag
Aug 05 01:45:39 raspberrypi sudo[6508]: pam_unix(sudo:session): session opened for user root by (uid=0)
lines 1386-1408/1408 (END)
Do I just start a new install of raspbian
Then try to do the install of the PIA and see how that goes.
For me this is experimentation.
Plus trying to figure out what changes I made and undo them is way more then I know .
