Pi - Linux - Replicate AndroidTV Feel
Hi
I’m currently installing pi os on my pi 4. I have this behind my tv and usually install libreelec. This time however I need a more complete OS (I need access to proxmox, spice and browser)
Is there any desktop that I can configure to look and feel like Android TV? Big clear icons, able to be used with a pretty dumb TV controller
Most times, I want it to be usable by people in the house that are not me and just want basic Kodi type interactions
You can put Android via Lineage OS on your raspberry pi. I’ve done this at my job from some different projects and it’s all worked very well. It can be a pain though but I’m willing to answer any questions you may have. But here is an Android TV project someone did on reedit which should be a good start for you: https://www.reddit.com/r/raspberry_pi/comments/1c8ozws/turn_your_raspberry_pi_4_into_an_android_tv/
Yeah I did look at the KonstaKang builds of Android. Unfortunately I had nothing but problems
I wanted to ideally avoid Android!
