I wish the GN video would have tested/shown it… (Like really: I wish GN would have shown every position with their modified AIO!)
But… They did not. They only showed it for:
Maybe it was (I don’t think we were able see it):
And:
All other cases were not tested! (I basically went frame by frame to check.) In my opinion they did not make a good job at presenting the results of their “experiment”.
The way you’ve drawn the water level in the res + tubes is not accurate to the way it would actually be. I assume theres some exaggeration here.
It could make a difference in that now you can pump air around the radiator in but with it oriented vertically that cant realistically happen because there isnt enough velocity to push the air down from the end caps.
Functionally though they are identical, and as far as makes no difference, the same.
I’m not trying to swing my dick here and flex on anyone. I used to design hydronic systems for a living. I know a couple things about moving water around
I think everyone here is mostly on the same page and ultimately just splitting hairs in finding the most ‘optimal’ configurations. We all agree on whats the best and whats the worst. The in between stuff is just a compromise. We fundamentally disagree on approaches that are more or less optimal.
The problem with the arguments made thus far is that most coolers have less than 10% air by volume, and they dont hold that much to begin with.
In the worst case scenarios where there is enough air to create a pocket by the pump and therefore causing issues with the circulator, you have likely reached the end of the useful life of that cooler. Permeation is a real issue, but it would take so long to cause enough air to accumulate that the hardware it was on would be obsolete.
These systems arent under pressure but also dont produce much flow to cause issues with cavitation. I think the problem with Gamers Nexus as a whole is that people put too much stock in what tech jesus says and miss the underlying messages he tries to convey. Missing the forest for the trees is what we say in english.
Ultimately the best operation of these pumps is with some amount of water above the pump as this puts just a bit of water column on it due to gravity, but this is not totally necessary.
Air noise is annoying but its not cavitation and wont destroy the pump.
Having air accumulate in the endcaps is OK and expected due to this area being much lower velocity.
