Photo Uploading
I have noticed that you can press reply when you upload a photo and the photo never uploads
Example
Uploading...
A side effect ive noticed is that i get these things
These stay like that for a Decent amount of time 1-10 minutes.
What format are you uploading?
I've noticed that uncompressed PNGs get stuck at 100%.
it works with all of them.
How big are the foto´s you like to upload?
File sizes are limmited.
it works with all allowed file sizes. just discourse allows you to press reply before it finishes uploading.
test
works fine at my end.
Uploading...
The image i just uploaded was a 1920 x 1080p wall paper of 538KB in size or so.
I´m not sure how big the file size is you try to upload.
But like i said its limmited.
like i said you have to be quick about it.
I suppose the problem might be on your end then.
one sec. i recorded a video of it. needs to process though.
You have this issue with all supported image formats?
Or only with png´s?
Unfortunatly i can´t look into the discourse settings atm, since i not have my admin privéleges back yet.
yeah works for all file formats
Hmm thats odd.
Wenn did these issues started?
And did you allready try to upload pictures to other sources?
it will work if i let it upload but if i press reply before it finishes then it just says uploading.
Well then i would suggest to let it finnish uploading firstly then.
hitting the reply button might just abort the upload proces.
Maybe your upload connection is just slow atm.
i know. just wondering if this was know or not
I imagine that this is something that the Discourse team is aware of and I'd imagine that there will be an update eventually. Right now we just have to live with that issue which isn't the end of the world for most users.
There is another problem, but it might just be a ME issue. My phone cannot upload pictures to here at all, allways throws errors saying the file format is wrong. I will say however that my phone is in a pretty bad state software wise which is causing other problems so it may just be that.
