This is a little more, which I know you were trying to cut costs (which you won't need thermal paste and fans). However with your build you will need at least dual channel DDR3-1866 since the GPU portion will be accessing your system memory with an APU...
The upside to my build that's worth the extra $50 is CUDA acceleration from an nVidia GPU in Adobe suite... so I feel you'll be happier with the overall experience from this... if you're cutting to budget as a premium priority cut the fans and thermal paste and pick up some decent 2x4GB DDR3-1866 (Corsair, Mushkin, GSkill, Crucial, Kingston, Adata) whatever's cheapest and doesn't have huge heatsinks that'll bang into your cooler
