I’m trying to install cpu-massive, and am hitting a number of missing files, and indeed, the XML seems to reference non-existent files.
Is this normal and expected, or anything I can do to fix it?
[8192] strpos(): Passing null to parameter #1 ($haystack) of type string is deprecated in phodevi_linux_parser:642
pts/apache-siege-1.0.5:
Test Installation 2 of 111
5 Files Needed [8 MB / 1 Minute]
Downloading: httpd-2.4.29.tar.bz2 [6.26MB]
Estimated Download Time: 1m ........................................
Downloading: apache-ab-test-files-1.tar.gz [0.01MB]
Downloading: apr-1.6.3.tar.bz2 [0.81MB]
Downloading: apr-util-1.6.1.tar.bz2 [0.41MB]
Download Failed: http://www.apache.org/dist/apr/apr-util-1.6.1.tar.bz2
Attempting to download from alternate mirror.
Download Failed: http://apache.cs.utah.edu//apr/apr-util-1.6.1.tar.bz2
If able to locate the file elsewhere, place it in the download cache and re-run the command.
Download Cache: /home/dave/.phoronix-test-suite/download-cache/
File Name: apr-util-1.6.1.tar.bz2
SHA256: d3e12f7b6ad12687572a3a39475545a072608f4ba03a6ce8a3778f607dd0035b
Downloading of needed test files failed.
