Hi all, I have had no luck fixing my issue on any other forum. Then I remembered this forum. Hope someone out there is smart enough to fix my problem.
I have a Droid turbo and I used Mofo root to get root back on android 4.4.4, used it again to upgrade to 5.1 while keeping root, used sunshine to unlock the bootloader when that came out, and finally installed TWRP recovery on it. I had not done much to it since, but had Intended to install cyanogenmod for a while.
Well I thought I would finally get to it this weekend. I made a nandroid back-up with TWRP, copied it to my computer, backed up some files I didn't want to lose, and went ahead and installed the latest version of cyanogenmod 13 for quark (Moto MAXX and Droid Turbo) and the necessary gapps. It all went very well. I booted into cyanogenmod just fine, and signed in to google.
I was in the process of setting things up, like preferences/wallpapers/wigets etc, while google downloaded my apps. Not long after I started doing this, nova launcher would repeatedly crash, as well as cyanogenmod's built in launcher. I got fed up with it and rebooted. But the phone shut down and started acting odd. It would show what looked like the bootloader, and I had no options at the top. Sometimes it would just say AP Fastboot Flash Mode (Secure) with no other text.
I got it to go to the bootloader after holding down the power and volume down button,(note the bootloader does not quite look normal for some reason) and got it to boot to TWRP. But TWRP said there is no OS installed, and it refused to install anything, wipe anything, and TWRP itself crashed after a bit when I left it there to try and use ADB to push my nandroid back up to it.
Now TWRP will not load from the bootloader, and I cannot flash anything. I wanted to just re-flash the stock firmware. So I downloaded fresh copies of it from the root thread on XDA developers (Cant find it anywhere else), but no matter what, i get the error "(bootloader) Failed to erase partition" It does this for anything. I tried flashing TWRP and the fresh system image. I tried following the steps on the root thread that flash things that you need to prepare the phone for the system image, but all attempts to flash fail with the same message.
Being a Motorola device, I can use mfastboot and adb, and with that I can mfastboot boot "a recovery like twrp". This will allow twrp to boot, but it cant mount any of the storage.
I also tried using mofo to flash a clean system image. (Mofo works by allowing modified official firmware to be flashed without a bootloader unlock) But it just stops and quits at 7%. I have had this problem before, and got around it by using mofo 0.0.2. But I no longer have that version. (0.0.3 is the current version)
One last thing, yesterday the phone randomly decided to boot into cyanogenmod just fine. After about 15 or so minutes of use, it abruptly rebooted and got stuck in a boot loop. I used TWRP manager to install twrp while the phone was working, and it could boot to that just fine. And it mounted everything. But when I tried to backup via my nandroid backup, it failed (possibly due to not having enough space) and the crashed. I'm back to where I was before. Can't flash anything, official or not, and can only get to TWRP via booting it directly with mfastboot boot twrp.iso. And that can't mount any of my storage.
I am at a loss here. I need my phone back ASAP. Any help would be much appreciated.
