Philips Fidelio X1 questions
I'm strongly considering buying these with my first PC Build.  So here are the questions:
1) Why the hell hasn't Logan reviewed these?  (I don't expect this one to be answered)
2) Because these are only 30 ohms, and I'd be using onboard audio (Z97 Pro Motherboard), is a DAC needed?
3) I plan on using headphones to listen to music and for gaming mostly.  Music will be Electronic, Classical, Rap, and Rock primarily.  I play a ton of BF4 already so hearing footsteps and voices is crucial.  Would the DT880 premiums be better for what I just listed?  Could the DT880's be powered by an iPhone or some android device?  I'd also like to be able to plug them into something like that when walking around the house and doing work between two different desks(one is a drafting table so there is no source to plug headphones into).
4) Lastly, if something should accompany the Fidelio X1's to improve the sound quality, what do you recommend? Right now I'm looking at the Audioengine D1.
Thanks!!!
