Phenom 965 overclock
im using the hyper 212 evo and ive never overclocked before does this look good or do you think i can push it some more
 cpuz
I was able to hit 4GHz with 1.44 V on my phenom II X4 I have in an older machine with the coolermaster V8, I think you can try to push higher :P
so i should lower my voltage u thing
In the BIOS :P I personally never use overdrive.
You could prolly lower your voltage back to near default and maintain that OC, or, depending on your motherboard, you could get to 4ghz, possibly with lower voltage then you have now.
I was hitting that speed on an ASRock 970 Ex3 with stock volt, just upped multipler... on stock cooling without heat issues.
