I asked for help on a similar topic here: https://teksyndicate.com/forum/cpu/decent-am3-place-holder-cpu/181250#comment-1733169
but do to things I had not planed for, my budget was spent on other things...
So I ask now,
Should I get a Phenom II x4 810 for $10-15 and a PRIME SD1484 cooler
or
a Phenom II x4 955 for $40-50 with the original heatsink
I can overclock with the base clock, so it doesn't necessarily need to be a BE...
thanks for any more advice (I'm a tard :/)
I also should add that I may get the Prime cooler for free...just a chance...
not sure if that changes anything.
Id go 810, then you can spend more money elsewhere like a used ssd.
I don't really need an SSD...I boot in 15 seconds on a regular harddrive...but interesting thought...
I'm leaning towards the 810 simply for the cost, but am unsure if there was/is any negative to choosing so (other than the slightly lower clock...but honestly...I'm on FM1, so anything will be faster)
also, should I get a PRIME SD1484 or a CNPS10X OPTIMA?
I see conflicting reviews on them...I would think the Prime would be quieter with bigger fans...but the Optima looks like it may cool better?
I'd say go for the 810. For $15 I think that's a really good buy.
okay, woot-
then that is a definite yes.
now I am thinking about the cooler...just because AMD chips get toasty...
Okay-so the 810 was sold before I could get it
So I just settled with a 720, IT'S STILL A HELL OF A LOT BETTER THAN WHAT I'M USING NOW THOUGH-
I don't game, so with some Overclocking, I'll satisfied with it for a while...I'll probably move to intel if amd doesn't release another cpu soon...
