I have a Phanteks Evolv X case, which has two LED strips, one along the side panel which is 30 LEDs long, and a removable front cover that has a two parallel strips (but are powered with one cable lead) which are 15 LEDs long. I also have a Fractal Design Celsius S24 (6 LEDs). All three of these are plugged into the RGB hub that came built into the case.
I am using OpenRGB as my controller. The problem is that OpenRGB addresses the strips as individual LED lights; so you have to define a length of the strip, so the software knows how many leds to address. OpenRGB sees the hub as the device. The strips are different lengths. The effect I’m trying to use has a solid base color and then a moving color that moves from one led to the next. Unfortunately if I set the length as the longest led strip attached to the hub, the other two will sit dark as the effect moves beyond it’s addressable space. If I set it to the shortest strip, the longer two will be addressed out to the 6th LED and then stop.
Does anybody have any ideas on how to address this? The hub is USB based. My motherboard only has 4 pin RGB headers; the cooler and strips are 3 pin.
