Pfsense set up for new SOGEA connection
Hi there, at work we have been running pfsense on an i3 sff PC behind a BT openreach VDSL FTTC modem for many years very successfully. We need pfsense for open VPN connections which require high bandwidth and it also helps separate out wired and wifi networks for security as sensitive data is involved. Recently we have been advised to move to SOGA internet as voice is getting turned off on out lines in a few years and we are using internet phones anyway. The SOGEA line has been installed and worked perfectly using the ISP supplied cheap £20 router / modem combo. However this is no good to us so I need to get it working with pfsense. I thought as SOGEA is basically just FTTC with no voice I could do away with the cheap ISP modem router and connect the line to the VDSL modem change the PPPoE user name and password and all would be good but no joy as the the internet doesn’t come up. I have got into the ISP router admin page and found a large number of setting shown in the attached images. Does anyone know if these can be replicated in pfsense an
d how to do it. Thanks for the help.
