I had not seen that list, thank you
Not a problem.
That should fix any issues you have, even if it’s not quite the way you’d care to be routing Netflix itself via VPN.
I tested PIA and some of their IP is working with Netflix. Also, I tried PureVPN, ExpressVPN and VyprVPN, only PureVPN is working with good speed.
We highly appreciate that you share your testing experiences with those vpn’s.
But this topic is allready 9 months old, so i guess that topic starter allready found,
a solution for his issue.
There for i’m going to lock this topic.
Before you decide to create a post please check the date of the the topic.
If you have more questions regarding reviving older topics.
Then please check here: Announcement: Reviving Old Threads Guideline Has Been Added to the FAQ
