Anyone have a list of urls for Amazon Prime Video steaming?
@Wendell @Ryan your puny Windows telemetry IP blocking list is for scrubs. A real list has 13k+ entries.
Here’s mine (including yours at the start):
List of 13,218 IPs, domains, and IP ranges tied to M$ telemetry and 3rd parties, .txt here: Windows Firewall Outbound rules - _Block - PFSense Formatted.txt (195.7 KB)
This was gathered from W10Privacy, Spybot Anti-Beacon, WindowsSpyBlocker, Windows10Privatizer etc. - Find them on Github. (Most of my research in my post from 2016.)
Updated this list on January 2018, but (the sources are) most likely not 100% fullproof.
Lol it seems crazy the os would be that chatty. What’s the high assurance bit that needs to be flipped on so we get the same experience as China and/or the dod? Lol
Edit. Turned your original 2016 post into a wiki and features it in our wiki section. It would rock if it were updated for 2018 and you mention what, if anything, this does for auto updates.
I believe 2/3 of that list is alternative IP addresses in case a. the main ip address failed, or b. it probably also depends on what part of the world you are in.
Yeah I totally want that Windows 10 China Government Edition <3
Cool. I’ll get to it soon-ish. I also need to specify that these IPs are also based on my preferences in the aforementioned programs (e.g. if you blocked Edge or Skype completely). What I do to update is I use W10Privacy’s builtin update picker & downloader
[EDIT] Done.
