The rule that matches first takes effect, and the rules are read top to bottom. But there is an invisible block all rule at the bottom, which is the default action. So you don't need to make a block rule bellow an allow rule because there's already one there but you do need a block rule above an allow rule if you wanted to block some part of what the allow rule is allowing.
Ok so I think I get it now. That was a bit to wrap my head around but I definitely feel like I learned something about the fundamental workings of firewall rules and networking there. Thanks for the clarification.
@Dexter_Kane How would you approach/troubleshoot with pfSense -- for example if you want CS:GO to run over WAN? What tools and methods in the firewall do you use to find blocked or wrong routed traffic?
When I set up block rules for MS telemetry quite a while ago, I followed a guide that also specified adding an alias and pass rule to ensure that Windows updates weren't being blocked. Here are the addresses specified:
Yeah, I assume that they probably do, and that blocking telemetry entirely is the not-so-simple matter of ditching Windows entirely, but I figure there's no harm in trying.
My VPN is going from USA > Toronto via PIA. But that shouldn't matter because the 3rd LAN rule should catch Netflix destination traffic and route it out my ISP WAN.
Yeah, but that isn't working for you, or did I misunderstand that. I meant that it might be different domains for different regions. Guess in NA it should be the same though... mh
If you can't find the ports by googling then what I'd do is make the rules with the ports you do know and create a block all rule under that (make sure you enable logging on the block rule). Then run the game and look at the firewall log in pfsense, look for traffic from the machine running the game and add the destination ports from the blocked traffic to the rule until the game works.
But if you have a game that needs port 443 or some other shared port there is no way for pfsense to tell which application the traffic is coming from. So the only thing you can do is either manually enable and disable the rule as needed or set up a proxy server that uses the VPN and manually set the browser to use that. That way Web traffic from t he browser goes to the proxy server and then over the VPN and any other traffic will go over the wan.
You could use squid on pfsense for this but it lacks any options for setting a gateway, it just uses the default gateway. So if the VPN is the default gateway then it will work other wise it won't. One thing to keep in mind about using the VPN as the default gateway is that if the VPN goes down then it will automatically use the wan connection as that will become the new default gateway until the VPN comes back up, which is why it's always better to specify gateways in your rules with an internet destination.
I'm wondering, why do you say it's a bad idea to do more than 50 ports in one rule? I'd think taking all the ports in the range 0-1023 and running them through the vpn would be a decent start at least, since that'd take all web and ssh and other such utilities through your vpn while leaving most game services untouched.
And yes, I know that range is way overkill, and you only need ports 20-30, 80, and 443 for the most common services.
They mean for a service that uses a bunch of ports in a range that that range will usually not be larger than 50 so making a rule with a range larger than thayb(if you don't specifically know which ports or range the service uses) may overlap with other services and cause problems.
You can make rules with as large a range as you like, it was more of a rule of thumb than any sort of technical limitation.
