Is there any way in PFSense to mask the IP of someone connecting and mask the IP as coming from a different range?
I have some device on the internal LAN with only accept communication from the same IP range. Means, when connecting to OpenVPN, I get into range 10.10.10.xx and the devices in question are on my internal IP range wich is 192.168.1.xx.
Are there any rules or routes I could set?
The only solution I found, is to reserve few IP’s in the DHCP server and setting the tunnel network of the open VPN server to the same as the internal (192.168.1.0/24).
Edit: actually not sure if it’s possible to set it for a single IP only just through the UI. It’s possible to add custom pf rules to do binat only when this one strange device is involved.
