Pfsense IPSec Site2Site not working
So, i’ve got 2 pfsense devices, one is a VM on my colocated server, one is on metal at home.
I recently set up a IPSec tunnel between them, it shows as up, but I can’t ping either side from each other. I don’t see anything fishy in the logs… I’ve verified configuration is identical on both sides, and changing encryption settings doesn’t seem to do anything. They both have a firewall rule to pass any traffic on the IPSec interface.
It’s gonna sound silly to ask, but they are allowing ICMP traffic?
on the LAN interface, yes
pings on the LAN respond but not through the tunnel
Sorry bud, I got nothing useful to suggest
that your tunnel is up is one point, what about your routing and Firewall rules?
https://docs.netgate.com/pfsense/en/latest/vpn/ipsec/firewall-rules.html
https://docs.netgate.com/pfsense/en/latest/routing/index.html
firewall rules on both sides are set to pass any and all traffic on IPSec
I can’t add a static route because it requires a gateway, and IPSec doesn’t provide a interface to add as a gateway
I don’t use IPsec, I’m still using OpenVPN at the moment, but I will change to Wireguard as soon the plugin works with CARP, or at least test it to see if it brings advantages.
Here the config for an IPsec Interface
https://docs.netgate.com/pfsense/en/latest/vpn/ipsec/routed-vti.html
Managed to figure it out. I now have a reliable site to site set up.
Now the question is, how do I get my mobile wireguard clients to get connections over the ipsec tunnel? I’m not sure how to add a route between them…
