Just finished watching the PfSense Video, and am excited to try it out but have some questions about hardware.
Currently, I have a Coax cable running into a modem my ISP gave me, which has Ethernet running to a router, which broadcasts WiFi and acts as a switch.
From what I understand, I would keep the same setup but replace the router with the PfSense machine, and for WiFi I could use the old router as a WiFi antennae?
Am I understanding this correctly?
Do I need to buy a NIC if I only have 1 ethernet port on the PfSense machine?
Is there a way to replace the modem by allowing the PfSense box to accept a Coax connection?
Thanks
