I've never used pfSense and unfortunately I don't have a spare computer to experiment with. I want to build a machine using the Asrock AD2550R/U3S3. I have a 50Mbit down connection and I want to use various plugins such as built in virus scanning, web caching, and probably others that I'll find once I build.
Is the Intel Atom D2550 that is soldered on the board powerful enough for this? How much RAM would you suggest? Should I install the OS on the same drive as the web caching drive or use a USB stick for the OS?
Thanks for the help
