HI.
Im running a PFSense router at home right now. and im trying to get the antivirus to work.
It behaves oddly when i try to change the settings for the proxy, It restores the settings from right before i changed them and then i get errors. this has happened when i tried to install snort as well but some how it just worked one day and has worked since.
Sep 9 22:22:50
php-fpm[73709]: /pkg_edit.php: HAVP: RAMDisk not used.
Diagnostic: system MB, available MB, calculated MB. Try reducing
‘MAXSCANSIZE’ value.
Sep 9 22:22:50
check_reload_status: Syncing firewall
Sep 9 22:22:50
Sep 9 22:22:50
php-fpm[73709]: /pkg_edit.php: Stopping HAVP
Sep 9 22:22:50
php-fpm[73709]: /pkg_edit.php: XML error: XML_ERR_NAME_REQUIRED at line 305 in /conf/config.xml
Sep 9 22:22:50
php-fpm[73709]: /pkg_edit.php: pfSense is restoring the configuration /cf/conf/backup/config-1441827825.xml
Sep 9 22:22:50
php-fpm[73709]: /pkg_edit.php: New alert found: pfSense is restoring the configuration /cf/conf/backup/config-1441827825.xml
Sep 9 22:22:50
Sep 9 22:22:50
check_reload_status: Reloading filter
Sep 9 22:22:50
Sep 9 22:22:51
php-fpm[73709]: /rc.filter_configure_sync: HAVP:
RAMDisk not used. Diagnostic: system MB, available MB, calculated MB.
Try reducing ‘MAXSCANSIZE’ value.
this is the errors that i get when i try to change any settings on the proxy
and the 305 line just said
< rrd>
< enable/>
< /rrd>
and i have changed the max scan size to 10k and i still get the error.
The system is a E6850 with 4gb or ram and a 256gb ssd
as a noob on linux i dont know what to do:S i thougt that i try asking here instead of just redoing the install and not learning anything:)
Thx for any help
/Dinez
