After watching the pfsense video Logan and Quain a while back I set out on a much needed task. I revived a pretty capable hp computer I had laying around, striped it down, and put in a intel 4 port gigabit server adapter I got on ebay and a wifi card and installed pfsense.
All this was done with the ultimate goal to replace my aging p.o.s. linksys router that is being held together with super glue and duct tape cheaply and to outperform its modern counterparts. The basic functionality that is needed is my router now preforms (4 gig lan and wifi) but of course I want to be able to take advantage of the scalability and advance features as I become for familiar with the software.
Excited I installed pfsense and got it up and running. Using the integrated gigabit port for wan and one of the four intel ports for lan. For my main rig, it was running smoothly. But when I went to configure the other three ports and the wifi I hit a road block. I enabled the interfaces no problem but they all were incapable of connecting to the internet. After much googleing and forum searches I still had no idea how to set them up so they can all access the internet.
With the resent update to 2.1 my will to get this up and running has returned, but I need your help. I am clueless when it comes to networking.
I understand that pfsense has limited wifi card support, but according to the pfsense website the processor used by my card [TP-Link Wireless N Dual Band PCI Express Adapter with 3 x 2dBi Antenna (TL-WDN4800)] should work, but this is not the end of the word because it was cheap and I would like to upgrade to ac in the future if possible.
What I need working first and foremost is enabling 4 lan ports so they would work in the most basic function, just like my old router. all able to connect to the internet and be apart of the same network.
Any input or suggestions would be greatly appreciated!
Thanks in advance,
Greg
