Hey and sorry for the long absence, I’ve been dealing with (unrelated, but actually solved by pfSense) internet issues. Somehow, my D-link router was messing up dialing through the bridge modem router and caused drops in the connection every 30 seconds or so.
It was a long journey and 3 separate technicians visits from my ISP and infrastructure provider (they are separate here, not sure if this is how it works where you live). Until I got tired and just pushed to move the dialer to the pfSense box.
But I digress, I am now fully deployed with pfSense and even found a few good configs for caching common stuff in squid on the pfSense.
I’ve looked at the link you shared, and it speaks only on setting up inline IPS between ports, I do not want that, I want both 10GbE ports to be in the LAN segment and have free traffic between them. Did I miss something in that link that was relevant?
The FreeBSD wiki link is interesting, but it states that I need an 8 core CPU before tuning to get 10Gb.
As for getting SFP cards, do they cost less? And if so, did you mean just use them as is and get SFP cables? Or with converters to Ethernet? I am willing to save as much as I can, since I’ll have to also buy cards for both endpoints, so replacing the cable runs with SFP is not really an option.
On a side note, in case anyone else follows in my footsteps in the future, I did find that there’s a DrayTek NIC that is also a vdsl2 modem that you can use in pfSense. If I was able to purchase that, it would also eliminate my modem and put that into the pfSense box. If anyone knows where I can get that, or something similar, I’d be very grateful.
It’s called the VigorNIC 132, in case anyone is interested.
