For the past two days I have been running into a strange issue with re-building my pfSense router. On my particular hardware: old Dell XPS630i running an Intel Core 2 duo E8400 CPU @ stock speeds of 3.00GHz and an ATI R3600 GPU, with 4GB DDR2 RAM. Previously I was able to somehow get pfsense onto a usb drive using YUMI, but as of late I haven't been able to use that for some reason. The following are all the options I have tried to get pfSense-CE-memstick-2.3.3-RELEASE-amd64(i386).img onto a USB drive so I can boot off of it using either an old USB 2.0 4GB flash drive or a newer 64GB corsaird survior flash drive:
- Downloaded both the 2.3.3 memstick amd64/i386 versions
- Also downloaded the ISO file of the same version
- Downloaded Rufus 2.12/Win32DiskImage/linux-debian-dd-gzip command on the pfsense website
* Installed debian onto the Dell system from the Corsair flash drive (just to check my sanity and make sure it was being seen) - Wiped the drives before each attempt
- Drag/dropped the .img files into rufus and used the defualt settings/DD option
- I am able to load a USB 3.0 YUMI based flash drive, that has a few troubleshooting tools on it just fine on the Dell system** (see not below)
**Tried to use the ISO with the 2 USB drives and all the programs, even YUMI but it keeps failing. Since it's an ISO why would it be acting differently, I have used YUMI to get ISO files of macrium reflect, winPE, win10 ISO and even DBAN onto a USB drive and it boots fine on all my systems, including this Dell system. - I have three different drives that I have used to try and get pfSense onto with the Dell system, but I keep getting into a bootloop with two of them. (the one already has debian on it, see above)
- Just a few weeks ago when I tried installing pfSense onto this machine I was able to get to the splash screen and it would start the install until I got an "error 19" message that might have something to do with this new issue. Then I mistakenly overwritten the USB drive that HAD pfsense on it, which was able to be booted off of
- I was able to get just the blinking "_" symbol with one of my attempts but nothing happened after that, not sure how/why/what I did that got it that far.
- I have tried using all my USB ports (before you even say it, YES they ALL work), I tested each port within the debian install to make sure the USB driver were in fact showing up along with my keyboard/mouse.
- Tried various SATA cables from the mobo to HDDs/other SATA ports, which all are working just fine becuase when I connected all 3 drives I could see them all inide the debian install.
- I think I turned off all the features I could including but not limited to: Virtualization, ACPI set to S1 instead of S3, "Drive A" (Floppy drive), auto restart, can't change HDD settings from AHCI to ata or vis versa (drives are connected via SATA cable/see above).
- According to dell and my service tag number I am running the latest BIOS version that my hardware supports (as far as I know)
Sorry for the long post, but I thought it prudent to mention all the steps I took, I may have forgotten a few, but that could just be due to the past 48 hours of hell I have been through trying to get this to work. Should also mention that when the first pfSense video went up on the previously named channel, I was able to get this same system loaded with pfsense, but I never did anything with it because at the time I had no control over the network I was on. Somehow that was how I was able to use YUMI to create a bootable drive.
Any and all help would be appreciated.
Sorry if this is in the wrong thread (admins, please move it if needed)
