Hello fellow humanz!
Recently – meaning a couple of month ago – my beloved/hated ASUS X99-deluxe motherboard died on me.
So I ended up buying an Gigabyte X99-UD4 on eBay.
I had a lot of issues with the board so far:
*the sound seems to be dead
*Windows worked for two days straight and then refused to ever boot again or even be re-installed from USB or DVD
*SATA doesn’t seem to really always work
After I finally managed to get Manjaro onto the SSD I ended up being mostly happy with the board. I will say that I will definitly try to one day fix the sound – maybe it is the sound chip, maybe just a cap (although I can see nothing obvious as far as damage is concerned and since the problem persists throughout Windows and Linux on bare metal I can rule out driver issues here) – but that will definitely need WAY more electronics knowledge then I have currently, SMD rework skill and patience and the willingness to take a risk, of which I have currently none. Oh, and schematics: but I found those already…
Since Windows on bare metal didn’t work for me I decided that a VM with a GPU passthrough was a good option. It worked well – after a few issues were sorted out – on my x99-deluxe and that was using the same Graphics cards, as well as the same Intel 5820k @ stock speeds.
Sadly now I have configured Virt-Manager installed the VM, got it to use the passthrough graphics card (Palit JetStream GeForce GTX 980) using this fix Fixing GPU Passthrough On Windows 10 VM In Proxmox - Virtualization - The Engineer's Workshop and to pin the cores the performance is so much worse then it was with the old mainboard. What can I do now?
Here are a couple of things that might help to assess my situation:
Specs:
OS and kernel:
Output of uname -a:
Linux goldsteal-x99-r-linux 5.14.7-2-MANJARO #1 SMP PREEMPT Wed Sep 22 12:22:56 UTC 2021 x86_64 GNU/Linux
Hardware
Output of cpu-x -D:
>>>>>>>>>> CPU <<<<<<<<<<
***** Processor *****
Vendor: Intel
Code Name: Broadwell-E (Core i7)
Package: SOCKET 0
Technology: 22 nm
Voltage: 0,730 V
Specification: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
Family: 0x6
Ext. Family: 0x6
Model: 0xF
Ext. Model: 0x3F
Temp.: 33°C
Stepping: 2
Instructions: HT, MMX, SSE(1, 2, 3, 3S, 4.1, 4.2), AVX(1, 2), FMA(3), AES, CLMUL, RdRand, VT-x, x86-64
***** Clocks *****
Core Speed: 1200 MHz
Multiplier: x12,0 (12-36)
Bus Speed: 99,96 MHz
Usage: 6,21 %
***** Cache *****
L1 Data: 6 x 32 kB, 8-way
L1 Inst.: 6 x 32 kB, 8-way
Level 2: 6 x 256 kB, 8-way
Level 3: 15 MB, 20-way
Socket(s): 1
Core(s): 6
Thread(s): 12
>>>>>>>>>> Caches <<<<<<<<<<
***** L1 Cache *****
Size: 6 x 32 kB, 8-way associative, 64-bytes line size
Speed: 92149,90 MB/s
***** L2 Cache *****
Size: 6 x 256 kB, 8-way associative, 64-bytes line size
Speed: 53242,90 MB/s
***** L3 Cache *****
Size: 15 MB, 20-way associative, 64-bytes line size
Speed: 32763,10 MB/s
>>>>>>>>>> Motherboard <<<<<<<<<<
***** Motherboard *****
Manufacturer: Gigabyte Technology Co., Ltd.
Model: X99-UD4-CF
Revision: x.x
***** BIOS *****
Brand: American Megatrends Inc.
Version: F23
Date: 06/07/2017
ROM Size: 64 kB / 16 MB
***** Chipset *****
Vendor: Intel Corporation
Model: C610/X99 series chipset LPC Controller
>>>>>>>>>> Memory <<<<<<<<<<
***** Bank 0 *****
Reference: Undefined KHX2666C15D4/8G , 8192 MB @ 2666 MHz (DIMM DDR4)
***** Bank 1 *****
***** Bank 2 *****
***** Bank 3 *****
***** Bank 4 *****
***** Bank 5 *****
***** Bank 6 *****
***** Bank 7 *****
>>>>>>>>>> System <<<<<<<<<<
***** Operating System *****
Kernel: Linux 5.14.7-2-MANJARO
Distribution: Manjaro Linux
Hostname: klasen-x99-r-linux
Uptime: 0 days, 1 hours, 32 minutes, 38 seconds
Compiler: cc (GCC) 11.1.0
***** Memory *****
Used: 3,41 GiB / 62,65 GiB
Buffers: 0,16 GiB / 62,65 GiB
Cached: 1,98 GiB / 62,65 GiB
Free: 57,10 GiB / 62,65 GiB
Swap: 0,00 GiB / 8,80 GiB
>>>>>>>>>> Graphics <<<<<<<<<<
***** Card 0 *****
Vendor: AMD
Driver: amdgpu
UMD Version:
Model: Tonga XT / Amethyst XT [Radeon R9 380X / R9 M295X]
DeviceID: 0x6938:0xF1
Interface: Current: PCIe Gen3x16 / Max: Gen3x16
Temperature: 47,00°C
Usage: 0%
Core Voltage: 0,98 V
Power Avg: 39,12 W
GPU clock: 681 MHz
Memory clock: 1500 MHz
Memory Used: 670 MiB / 4096 MiB
***** Card 1 *****
Vendor: NVIDIA
Driver: vfio-pci
UMD Version:
Model: GM204 [GeForce GTX 980]
DeviceID: 0x13C0:0xA1
Interface:
Temperature:
Usage:
Core Voltage:
Power Avg:
GPU clock:
Memory clock:
Memory Used:
Virt-Manager XML:
<domain type="kvm">
<name>win10</name>
<uuid>53e9225b-3a32-4e0a-86ca-8b115547a445</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/10"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">16777216</memory>
<currentMemory unit="KiB">16777216</currentMemory>
<vcpu placement="static">8</vcpu>
<cputune>
<vcpupin vcpu="0" cpuset="2"/>
<vcpupin vcpu="1" cpuset="8"/>
<vcpupin vcpu="2" cpuset="3"/>
<vcpupin vcpu="3" cpuset="9"/>
<vcpupin vcpu="4" cpuset="4"/>
<vcpupin vcpu="5" cpuset="10"/>
<vcpupin vcpu="6" cpuset="5"/>
<vcpupin vcpu="7" cpuset="11"/>
<emulatorpin cpuset="0-1,6-7"/>
</cputune>
<os>
<type arch="x86_64" machine="pc-q35-6.1">hvm</type>
<loader readonly="yes" type="pflash">/usr/share/edk2-ovmf/x64/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
<vendor_id state="on" value="randomid"/>
</hyperv>
<kvm>
<hidden state="on"/>
</kvm>
</features>
<cpu mode="host-passthrough" check="none" migratable="on">
<topology sockets="1" dies="1" cores="4" threads="2"/>
</cpu>
<clock offset="utc">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
<timer name="kvmclock" present="yes"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="file" device="disk">
<driver name="qemu" type="qcow2"/>
<source file="/var/lib/libvirt/images/win10.qcow2"/>
<target dev="sda" bus="sata"/>
<boot order="1"/>
<address type="drive" controller="0" bus="0" target="0" unit="0"/>
</disk>
<disk type="file" device="cdrom">
<driver name="qemu" type="raw"/>
<source file="/home/goldsteal/Downloads/Win10_21H1_English_x64.iso"/>
<target dev="sdb" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="1"/>
</disk>
<source file="/var/lib/libvirt/images/win10-1.qcow2"/>
<target dev="sdc" bus="sata"/>
<address type="drive" controller="0" bus="0" target="0" unit="2"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x8"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x9"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0xa"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0xb"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0xc"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0xd"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x5"/>
</controller>
<controller type="pci" index="7" model="pcie-root-port">
<target chassis="7" port="0xe"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x6"/>
</controller>
<controller type="pci" index="8" model="pcie-to-pci-bridge">
<model name="pcie-pci-bridge"/>
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
</controller>
<controller type="pci" index="9" model="pcie-root-port">
<target chassis="9" port="0xf"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x7"/>
</controller>
<interface type="network">
<mac address="52:54:00:c6:d9:26"/>
<source network="default"/>
<model type="e1000e"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</interface>
<serial type="pty">
<target type="isa-serial" port="0">
<model name="isa-serial"/>
</target>
</serial>
<console type="pty">
<target type="serial" port="0"/>
</console>
<input type="mouse" bus="virtio">
<address type="pci" domain="0x0000" bus="0x09" slot="0x00" function="0x0"/>
</input>
<input type="keyboard" bus="virtio">
<address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
</input>
<input type="keyboard" bus="ps2"/>
<input type="mouse" bus="ps2"/>
<graphics type="spice" autoport="yes">
<listen type="address"/>
<image compression="off"/>
<gl enable="no"/>
</graphics>
<audio id="1" type="none"/>
<video>
<model type="none"/>
</video>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x03" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</hostdev>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</memballoon>
<shmem name="looking-glass">
<model type="ivshmem-plain"/>
<size unit="M">32</size>
<address type="pci" domain="0x0000" bus="0x08" slot="0x01" function="0x0"/>
</shmem>
</devices>
</domain>
Output of lspci -knn
00:00.0 Host bridge [0600]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DMI2 [8086:2f00] (rev 02)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5000]
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 1 [8086:2f02] (rev 02)
Kernel driver in use: pcieport
00:01.1 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 1 [8086:2f03] (rev 02)
00:02.0 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 2 [8086:2f04] (rev 02)
DeviceName: Onboard IGD
00:02.3 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 2 [8086:2f07] (rev 02)
00:03.0 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 3 [8086:2f08] (rev 02)
00:05.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Address Map, VTd_Misc, System Management [8086:2f28] (rev 02)
Subsystem: Intel Corporation Device [8086:0000]
00:05.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Hot Plug [8086:2f29] (rev 02)
00:05.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 RAS, Control Status and Global Errors [8086:2f2a] (rev 02)
00:11.0 Unassigned class [ff00]: Intel Corporation C610/X99 series chipset SPSR [8086:8d7c] (rev 05)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:7270]
00:14.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB xHCI Host Controller [8086:8d31] (rev 05)
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:16.0 Communication controller [0780]: Intel Corporation C610/X99 series chipset MEI Controller #1 [8086:8d3a] (rev 05)
Kernel driver in use: mei_me
Kernel modules: mei_me
00:19.0 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2) I218-V [8086:15a1] (rev 05)
DeviceName: Onboard LAN
Subsystem: Gigabyte Technology Co., Ltd Device [1458:e000]
Kernel driver in use: e1000e
Kernel modules: e1000e
00:1a.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #2 [8086:8d2d] (rev 05)
Kernel driver in use: ehci-pci
00:1b.0 Audio device [0403]: Intel Corporation C610/X99 series chipset HD Audio Controller [8086:8d20] (rev 05)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:a182]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge [0604]: Intel Corporation C610/X99 series chipset PCI Express Root Port #1 [8086:8d10] (rev d5)
00:1d.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #1 [8086:8d26] (rev 05)
00:1f.0 ISA bridge [0601]: Intel Corporation C610/X99 series chipset LPC Controller [8086:8d47] (rev 05)
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller [0106]: Intel Corporation C610/X99 series chipset 6-Port SATA Controller [AHCI mode] [8086:8d02] (rev 05)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:b002]
Kernel driver in use: ahci
00:1f.3 SMBus [0c05]: Intel Corporation C610/X99 series chipset SMBus Controller [8086:8d22] (rev 05)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
03:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM204 [GeForce GTX 980] [10de:13c0] (rev a1)
Subsystem: NVIDIA Corporation GM204 [GeForce GTX 980] [10de:13c0]
Kernel driver in use: vfio-pci
Kernel modules: nouveau
03:00.1 Audio device [0403]: NVIDIA Corporation GM204 High Definition Audio Controller [10de:0fbb] (rev a1)
Subsystem: NVIDIA Corporation Device [10de:13c0]
05:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Tonga XT / Amethyst XT [Radeon R9 380X / R9 M295X] [1002:6938] (rev f1)
Subsystem: PC Partner Limited / Sapphire Technology Radeon R9 380X Nitro 4G D5 [174b:e308]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
05:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Tonga HDMI Audio [Radeon R9 285/380] [1002:aad8]
Subsystem: PC Partner Limited / Sapphire Technology Radeon R9 285/380 HDMI Audio [174b:aad8]
06:00.0 Non-Volatile memory controller [0108]: Kingston Technology Company, Inc. A2000 NVMe SSD [2646:2263] (rev 03)
Subsystem: Kingston Technology Company, Inc. A2000 NVMe SSD [2646:2263]
Kernel driver in use: nvme
ff:0b.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f81] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f81]
ff:0b.1 Performance counters [1101]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f36] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f36]
Kernel driver in use: hswep_uncore
ff:0b.2 Performance counters [1101]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f37] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring [8086:2f37]
ff:0c.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe0] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe0]
ff:0c.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe1] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe1]
ff:0c.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe2] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe2]
ff:0c.3 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe3] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe3]
ff:0c.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe4] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe4]
ff:0c.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe5] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers [8086:2fe5]
ff:0f.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Buffered Ring Agent [8086:2ff8] (rev 02)
ff:0f.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Buffered Ring Agent [8086:2ff9] (rev 02)
ff:0f.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers [8086:2ffc] (rev 02)
Subsystem: Intel Corporation Device [8086:2fe0]
ff:0f.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers [8086:2ffd] (rev 02)
ff:0f.6 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers [8086:2ffe] (rev 02)
ff:10.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface [8086:2f1d] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface [8086:2f1d]
ff:10.1 Performance counters [1101]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface [8086:2f34] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface [8086:2f34]
ff:10.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f1e] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f1e]
ff:10.6 Performance counters [1101]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f7d] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f7d]
ff:10.7 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f1f] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers [8086:2f1f]
ff:12.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 [8086:2fa0] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 [8086:2fa0]
ff:12.1 Performance counters [1101]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 [8086:2f30] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 [8086:2f30]
ff:13.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers [8086... (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers [8086:2fa8]
ff:13.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers [8086... (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers [8086:2f71]
ff:13.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2faa] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2faa]
ff:13.3 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fab] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fab]
ff:13.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fac] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fac]
ff:13.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fad] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder [8086:2fad]
ff:13.6 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Channel 0/1 Broadcast [8086:2fae] (rev 02)
ff:13.7 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Global Broadcast [8086:2faf] (rev 02)
ff:14.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 Thermal Control [8086:2fb0] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 Thermal Control [8086:2fb0]
ff:14.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 Thermal Control [8086:2fb1] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 Thermal Control [8086:2fb1]
ff:14.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 ERROR Registers [8086:2fb2] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 ERROR Registers [8086:2fb2]
ff:14.3 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 ERROR Registers [8086:2fb3] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 ERROR Registers [8086:2fb3]
ff:14.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 [8086:2fbc] (rev 02)
ff:14.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 [8086:2fbd] (rev 02)
ff:14.6 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 [8086:2fbe] (rev 02)
ff:14.7 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 [8086:2fbf] (rev 02)
ff:15.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 Thermal Control [8086:2fb4] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 Thermal Control [8086:2fb4]
ff:15.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 Thermal Control [8086:2fb5] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 Thermal Control [8086:2fb5]
ff:15.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 ERROR Registers [8086:2fb6] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 ERROR Registers [8086:2fb6]
ff:15.3 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 ERROR Registers [8086:2fb7] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 ERROR Registers [8086:2fb7]
ff:16.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 1 Target Address, Thermal & RAS Registers [8086... (rev 02)
ff:16.6 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Channel 2/3 Broadcast [8086:2f6e] (rev 02)
ff:16.7 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Global Broadcast [8086:2f6f] (rev 02)
ff:17.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 1 Channel 0 Thermal Control [8086:2fd0] (rev 02)
ff:17.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 [8086:2fb8] (rev 02)
ff:17.5 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 [8086:2fb9] (rev 02)
ff:17.6 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 [8086:2fba] (rev 02)
ff:17.7 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 [8086:2fbb] (rev 02)
ff:1e.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f98] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f98]
ff:1e.1 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f99] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f99]
ff:1e.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f9a] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f9a]
ff:1e.3 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2fc0] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2fc0]
ff:1e.4 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f9c] (rev 02)
Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit [8086:2f9c]
ff:1f.0 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 VCU [8086:2f88] (rev 02)
ff:1f.2 System peripheral [0880]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 VCU [8086:2f8a] (rev 02)
As you can see my passthrough GPU is 03.00.0.
In case you need more here is the output of lspci -knnvvv
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 0
NUMA node: 0
IOMMU group: 12
Capabilities: <access denied>
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 1 [8086:2f02] (rev 02) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 26
NUMA node: 0
IOMMU group: 13
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000f000-00000fff [disabled]
Memory behind bridge: fff00000-000fffff [disabled]
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [disabled]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
00:01.1 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 1 [8086:2f03] (rev 02) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 27
NUMA node: 0
IOMMU group: 14
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
00:02.0 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 2 [8086:2f04] (rev 02) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 28
NUMA node: 0
IOMMU group: 15
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: de000000-df0fffff [size=17M]
Prefetchable memory behind bridge: 00000000a0000000-00000000b1ffffff [size=288M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
00:02.3 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 2 [8086:2f07] (rev 02) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 29
NUMA node: 0
IOMMU group: 16
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
00:03.0 PCI bridge [0604]: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 3 [8086:2f08] (rev 02) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 30
NUMA node: 0
IOMMU group: 17
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: df200000-df2fffff [size=1M]
Prefetchable memory behind bridge: 00000000c0000000-00000000d01fffff [size=258M]
BridgeCtl: Parity- SERR+ NoISA- VGA+ VGA16+ MAbort- >Reset- FastB2B-
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
NUMA node: 0
IOMMU group: 18
NUMA node: 0
IOMMU group: 19
NUMA node: 0
IOMMU group: 20
NUMA node: 0
IOMMU group: 21
00:14.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB xHCI Host Controller [8086:8d31] (rev 05) (prog-if 30 [XHCI])
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin D routed to IRQ 19
NUMA node: 0
IOMMU group: 22
Region 0: Memory at df320000 (64-bit, non-prefetchable) [size=64K]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 46
NUMA node: 0
IOMMU group: 23
Region 0: Memory at df33c000 (64-bit, non-prefetchable) [size=16]
Latency: 0
Interrupt: pin A routed to IRQ 47
NUMA node: 0
IOMMU group: 24
Region 0: Memory at df300000 (32-bit, non-prefetchable) [size=128K]
Region 1: Memory at df339000 (32-bit, non-prefetchable) [size=4K]
Region 2: I/O ports at f020 [size=32]
00:1a.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #2 [8086:8d2d] (rev 05) (prog-if 20 [EHCI])
Latency: 0
Interrupt: pin C routed to IRQ 18
NUMA node: 0
IOMMU group: 25
Region 0: Memory at df338000 (32-bit, non-prefetchable) [size=1K]
Interrupt: pin A routed to IRQ 48
NUMA node: 0
IOMMU group: 26
Region 0: Memory at df330000 (64-bit, non-prefetchable) [size=16K]
00:1c.0 PCI bridge [0604]: Intel Corporation C610/X99 series chipset PCI Express Root Port #1 [8086:8d10] (rev d5) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 31
NUMA node: 0
IOMMU group: 27
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
Memory behind bridge: df100000-df1fffff [size=1M]
00:1d.0 USB controller [0c03]: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #1 [8086:8d26] (rev 05) (prog-if 20 [EHCI])
Latency: 0
NUMA node: 0
IOMMU group: 28
Region 0: Memory at df337000 (32-bit, non-prefetchable) [size=1K]
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
NUMA node: 0
IOMMU group: 29
00:1f.2 SATA controller [0106]: Intel Corporation C610/X99 series chipset 6-Port SATA Controller [AHCI mode] [8086:8d02] (rev 05) (prog-if 01 [AHCI 1.0])
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 33
NUMA node: 0
IOMMU group: 29
Region 0: I/O ports at f070 [size=8]
Region 1: I/O ports at f060 [size=4]
Region 2: I/O ports at f050 [size=8]
Region 3: I/O ports at f040 [size=4]
Region 4: I/O ports at f000 [size=32]
Region 5: Memory at df336000 (32-bit, non-prefetchable) [size=2K]
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
NUMA node: 0
IOMMU group: 29
Region 0: Memory at df335000 (64-bit, non-prefetchable) [size=256]
Region 4: I/O ports at 0580 [size=32]
03:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM204 [GeForce GTX 980] [10de:13c0] (rev a1) (prog-if 00 [VGA controller])
Physical Slot: 6
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 11
NUMA node: 0
IOMMU group: 30
Region 0: Memory at de000000 (32-bit, non-prefetchable) [disabled] [size=16M]
Region 1: Memory at a0000000 (64-bit, prefetchable) [disabled] [size=256M]
Region 3: Memory at b0000000 (64-bit, prefetchable) [disabled] [size=32M]
Region 5: I/O ports at e000 [disabled] [size=128]
Expansion ROM at df000000 [disabled] [size=512K]
Physical Slot: 6
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin B routed to IRQ 10
NUMA node: 0
IOMMU group: 30
Region 0: Memory at df080000 (32-bit, non-prefetchable) [size=16K]
05:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Tonga XT / Amethyst XT [Radeon R9 380X / R9 M295X] [1002:6938] (rev f1) (prog-if 00 [VGA controller])
Physical Slot: 4
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 50
NUMA node: 0
IOMMU group: 31
Region 0: Memory at c0000000 (64-bit, prefetchable) [size=256M]
Region 2: Memory at d0000000 (64-bit, prefetchable) [size=2M]
Region 4: I/O ports at d000 [size=256]
Region 5: Memory at df200000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at 000c0000 [disabled] [size=128K]
Physical Slot: 4
Interrupt: pin B routed to IRQ 49
NUMA node: 0
IOMMU group: 31
Region 0: Memory at df260000 (64-bit, non-prefetchable) [size=16K]
06:00.0 Non-Volatile memory controller [0108]: Kingston Technology Company, Inc. A2000 NVMe SSD [2646:2263] (rev 03) (prog-if 02 [NVM Express])
Interrupt: pin A routed to IRQ 16
NUMA node: 0
IOMMU group: 32
Region 0: Memory at df100000 (64-bit, non-prefetchable) [size=16K]
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
IOMMU group: 0
IOMMU group: 0
IOMMU group: 0
IOMMU group: 1
IOMMU group: 1
IOMMU group: 1
IOMMU group: 1
IOMMU group: 1
IOMMU group: 1
IOMMU group: 2
IOMMU group: 2
IOMMU group: 2
IOMMU group: 2
IOMMU group: 2
IOMMU group: 3
IOMMU group: 3
IOMMU group: 3
IOMMU group: 3
IOMMU group: 3
IOMMU group: 4
IOMMU group: 4
IOMMU group: 5
IOMMU group: 5
IOMMU group: 5
IOMMU group: 5
IOMMU group: 5
IOMMU group: 5
IOMMU group: 5
IOMMU group: 5
IOMMU group: 6
IOMMU group: 6
IOMMU group: 6
IOMMU group: 6
IOMMU group: 6
IOMMU group: 6
IOMMU group: 6
IOMMU group: 6
IOMMU group: 7
IOMMU group: 7
IOMMU group: 7
IOMMU group: 7
IOMMU group: 8
IOMMU group: 8
IOMMU group: 8
IOMMU group: 9
IOMMU group: 9
IOMMU group: 9
IOMMU group: 9
IOMMU group: 9
IOMMU group: 10
IOMMU group: 10
IOMMU group: 10
IOMMU group: 10
Region 0: I/O ports at <ignored> [disabled]
IOMMU group: 10
IOMMU group: 11
IOMMU group: 11
cat /sys/devices/system/clocksource/clocksource0/current_clocksource:
tsc
