Pentium g +7870
if i get the pentium g860 and combine it with the radeon 7870 will i be bottlenecking the cpu?
Yes,there will indeed be a bottleneck.
i see, what about pairing it with the 7770?
Maybe. I don't suggest the pentium at all though.
how come?
What exactly is your budget,what do you plan on using this computer for,we could wip up a nice hefty build for you.
What about a Phenom II x4 965? It shouldn't bottleneck it too much and it's just a bit more expensive.
my budget is around 400-500 $ i dont need a dvd drive or hard drives because i already have them,
http://pcpartpicker.com/p/FguX a tad over your budget,but this is a huge improvement.
hmm thank yoyu very much
What tonychau123 posted is perfect, but if money is kind of a problem you can just go with the Phenom II x4 965
Thanks for your compliment!
hey tony can u make me one for 400 too pls
There is no RAM...
Because it won't be able to handle many games......or really anything. I'd only buy it for a super budget web surfer.
This is a good build, it's $560, pretty much cheap as it gets if you don't want any bottleneck. http://pcpartpicker.com/p/EIWE
