Av78
September 7, 2024, 6:21pm
1
I have recently build a pc ( around a month ago). In the past week while I was gaming suddenly the screen turned off and fans were running at full blast. I could not use it at all, tried CTRL+ALT+DEL but no luck. I then manually turned it off and on again and it was running fine till today.
I was gaming and left the game open for an hr while i was away, when I came back and realized that I checked my thermals and the cpu was 72c and gpa around 67c. Then I gamed for at least 1 more hr till the issue happened again.
My current cpu is a 7800x3d and gpu 4080 super. Does anyone have any idea what could be causing the issue?
Seems reasonable to me.
What parts are the rest of the system?
The more info the more precise the tips you get.
Av78
September 9, 2024, 10:52am
3
Full spec list follows below:
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core
CPU Cooler: Corsair iCUE H100i ELITE CAPELLIX XT 65.57 CFM Liquid CPU Cooler
Motherboard: Asus TUF GAMING B650-PLUS WIFI ATX AM5 Motherboard
Memory: Corsair Vengeance RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory
Storage:
Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
512 GB WD Black PCIe® NVMe™ TLC M.2 SSD
3)1 TB 7200 rpm Toshiba SATA HDD
Video Card: Gigabyte WINDFORCE V2 GeForce RTX 4080 SUPER 16 GB Video Card
Case: Corsair 5000D CORE AIRFLOW ATX Mid Tower Case
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Note storage 2 and 3 were transferred from my old system and both are used as additional storage. The new ssd I bought is used as the boot drive.
Av78
September 9, 2024, 10:53am
4
Thank you, I have added the full list of a specs in a comment if it helps.
Assuming you are on Windows are there any critical errors in event viewer?
Are you running any overclock on cpu,memory or gpu, have you undervolted anything?
Is the system otherwise stable, do you have any other issues, did you do stress testing when you put the machine together?
Is it happening in one particular game or multiple, and do the games themselves produce crash logs?
I’ve had similar issues in the past that were caused by bad memory timings and overly agressive undervolting.
Type in start menu memory test and run it
Av78
September 9, 2024, 2:29pm
7
I have done the following stress test:
Cinbebench R24 30 mins, stable at around 82c
furmark for the GPU which run pass through easily around 65c
Aida 64 SHA3 for memory oc stability
My CPU is running on stock settings, with the only OC as I mentioned above is my ram which run at 6000mhz.
This currently, happened with 2 games. In other things such as media consumption and productivity have not shown any issue.
Try OCCT for the memory bench for about an hour. Its great for seeking out issues.
frred
September 12, 2024, 1:40pm
9
Which fans spin to 100%?
System?
CPU?
GPU?
