This will be my final build that i will hopefully make unless newer and better things come out in a few months, but i dont know what case to use and is the power supply good enough? i want the case to be $75 or less.
i would like it to stay cool so maybe add some fans that i can add to the fan but please make sure they are quiet i dont like loud computers.
I will be buying a SSD later i just dont see any reason to get one yet.
My budget is $1200 so feel free to modify anything and show me.
PLEASE HELP ME this will be final choice build and i want it to be worth it.
The power supply is definitely good enough. For a case you could go with a Zalman Z11, Corsair 300R, CoolerMaster Storm Series case (I'm personally gonna get a Storm Scout 2 for a build),, CoolerMaster HAF 922, Rosewill Blackhawk, etc... There are a ton of cases for under $75, the one's I mentioned have really good airflow and if you want some case fans go for Noctua's if you don't care about the color, they're pretty silent and have good air pressure. You can also get Corsair SP120 quiet edition fans if you want.
thanks i have one question does a fans rpm affect the sound? i see the corsair air series and theres a 1100 rpm then 1 450 rpm which ones should i go with after you tell me ill finish my build and share the link so you can see if you want
The power supply you chose isn't the more reliable of the Corsair units. It is worth getting a good power supply... I mean would you feed A McLaren F1 Regular Unleaded Low Octane Fuel? Less Power is converted into heat with a better Power supply as well.
Motherboard wise the UD5 has better components allowing for more stable operation when Overclocked. Again you chose the top gun AMD CPU... get a decent Motherboard to put it in. My 2 cents.
Yeah, RPM means rotations per minute obviously, and a small fan with high RPM is gonna be really loud while a big fan with low rpm is gonna be quieter, but the bigger fan will be able to move more air due to it's sheer size meaning that you don't need to get one with a high RPM. A perfect example is a 240mm fan with an RPM of 1500, it's gonna push a lot of air through at a standard RPM whilst a 120 wouldn't push as much air through at the same RPM.
I like recommending the NZXT Source 200, it has a huge amount of mesh and the capacity for two 140mm fans in the roof, two 120mm fans in the front ans another 120mm fan in the back. Lots of potential cooling locations, it has cable management holes, but no grommets for them. So if you are okay with a $50 case that offers some really nice options, I would certainly recommend it. Also, some really nice fans:
ASRock motherboards have a large failure rate... the highest in the industry. They're made cheap (hence why they cost less). People recommend them far too often. ASRock is akin to ECS. Both came into being as budget brands.
No way in hell I'd recommend an ASRock board myself: http://www.guru3d.com/news-story/list-of-hardware-failure-rates.html
If your already set on windows 8 buy it, but so far windows 7 has proved to be sooo much better for gaming. Most keyboard and other peripherals dont work with windows 8 very well. If you want to upgrade in the future its only like $40 to upgrade from windows 7 to windows 8.
yeah ill stick with windows 7 so i know i wont have problems, but i have windows 7 right now and im having a hard time with updates, it just wont let me errors all the time ive tried everything other people say to do but nothing.
