Hello everyone, I’m looking for an answer how exactly PCIexpress configuration changes and how bandwidth availability works, when earlier PCIe generation devices are used.
I’m looking to upgrade to Ryzen 9000-series soon and looking into the motherboards and having a hard time finding the one that fits my needs. At this point, MPG X870E CARBON WIFI looks to be the best choice. Mostly due to the PCIe port & M.2 layout.
I’m currently running 2 M.2 SSDs (One for / and one for /home) and 4xSATA as a RAID0 for /mnt/ssd mount point, basically where all games, videos and temporary big data lives.
Ideally I want to switch to 1 M.2 for /, 2xM.2 in RAID1 for /home and 1 M.2 for similar /mnt/nvme, which probably still outperforms 4xSATA drives.
What I don’t exactly understand, how PCIe would work, if I’ll put gen4 + gen3 nvme ssd and PCIe gen4 GPU (7900XTX) into this.
Motherboard manual says, that PCIe ports work either in PCIe Gen5 x16 (PCIe_E1) or PCIe Gen5 8x (PCIe_E1) + PCIe Gen5 4x (PCIe_E2) + PCIe Gen5 4x (M2_2).
Since GPU is Gen4 x16, PCIe Gen5 x8 - is exactly the same, but it’s still x16 electrically, so does it mean that Gen4 x16 card would work in a latter configuration (x8 + x4 + x4)?
Also putting device into chipset ports (both m.2 and PCIe), how limited are those? IIRC chipset is only connected to the CPU by Gen5(?) x8 lane?
Basically what I’m asking, how smart and dynamic PCIe generally is? If I’m not using all the devices connected at 100% all the time, each individual device should work at 100% at given time, correct?
