I am attempting to setup PCIe passthrough to a windows virtual machine on my secondary rig. I have tried several different tutorials, including Wendell’s, and to no avail. I’m not entirely sure whether it is an issue with the hardware or my operating system, but I am suspecting it might be compatibility issues with my hardware, as it is a bit dated. I am running dual Xeon X5650s with 24GB of DDR3 ECC RAM. My motherboard is a Supermicro X8DTL-iF and the graphics card I am trying to passthrough is a NVidia GTX 960. For my operating system I running Fedora 29. VT-x and VT-d are both enabled in the BIOS, IOMMU grouping seems to be working, and the graphics card is “claimed by stub”. Everything appears to be working properly until the VM is actually booted and the graphics card simply has no output, however I can see the VM running in virt-manager’s spice window. Even when the spice channel is removed, there is still no output from the graphics card. Any help or suggestions as to what I might do would be much appreciated.
What version of windows? And are you using OVMF instead of bios? Does the graphics card show in the vm’s device manager?
Does the GPU show up in the virtual machine? lscpi for linux, or device manager for windows? Double check that you have drivers installed?
