PCI Passthrough - QEMU/KVM VM Struggle Bus
Hey guys, new to Level1Forums.
I’m attempting to spin up a virtual machine (virt-manager) with PCI pass-through of my Nvidia GTX 1080 to a Windows 10 VM. I followed a couple of super useful tutorials on Youtube (Would be linked, but they dont like that here I guess). My eventual goal is to game on the VM and try out Looking Glass. Right now I have a dual boot setup for gaming titles that have bs DRM or anti-cheap software.
I’m getting to the very end and come up with this error.
Unable to complete install: 'unsupported configuration: host doesn't support passthrough of host PCI devices'
Traceback (most recent call last):
  File "/usr/share/virt-manager/virtManager/asyncjob.py", line 75, in cb_wrapper
    callback(asyncjob, *args, **kwargs)
  File "/usr/share/virt-manager/virtManager/createvm.py", line 2089, in _do_async_install
    guest.installer_instance.start_install(guest, meter=meter)
  File "/usr/share/virt-manager/virtinst/install/installer.py", line 542, in start_install
    domain = self._create_guest(
  File "/usr/share/virt-manager/virtinst/install/installer.py", line 491, in _create_guest
    domain = self.conn.createXML(install_xml or final_xml, 0)
  File "/usr/lib/python3.8/site-packages/libvirt.py", line 4035, in createXML
    if ret is None:raise libvirtError('virDomainCreateXML() failed', conn=self)
libvirt.libvirtError: unsupported configuration: host doesn't support passthrough of host PCI devices
Specs and configuration are as listed:
Manjaro 20 Gnome (latest release)
Intel Core i5 6600k @ 4.6Ghz
16gb of RAM
Gigabyte Z170 mobo
PNY Nvidia GTX 1080 8GB
A couple of Samsung 500gb SSDs,
WD 1TB HDD
And before anybody asks, yes VT-d is enabled.
Something I noticed while following either of those two tutorials, when I ran the command ‘sudo dmesg | grep -i vfio’ , it returned with (error -22)
[    1.314392] VFIO - User Level meta-driver version: 0.3
[    1.317249] vfio-pci: probe of 0000:01:00.0 failed with error -22
[    1.317251] vfio_pci: add [10de:1b80[ffffffff:ffffffff]] class 0x000000/00000000
[    1.317255] vfio-pci: probe of 0000:01:00.0 failed with error -22
[    1.317290] vfio-pci: probe of 0000:01:00.1 failed with error -22
[    1.317292] vfio_pci: add [10de:10f0[ffffffff:ffffffff]] class 0x000000/00000000
I’ve tried following the tutorials with close detail about 4 or 5 times now and i’m still tripping up on something. Any help would be greatly appreciated.
Hi, welcome to the forums.
I’ll do my best to help you get this VM up and running.
First off, would you be able to run lspci -k in terminal for me and post the results?
Could you also run lspci -nn to find your gpu device address and then
find /sys/kernel/iommu_groups/ -type l to check the iommu groups, post them here as well.
It seems like the host is not configured to support pci passthrough, have you enabled this at boot through grub or modprobe?
That is the intel_iommu option in either grub config or a modprobe.
Thanks for the reply!
Here is the lspci -k
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
	Subsystem: Gigabyte Technology Co., Ltd Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers
	Kernel driver in use: skl_uncore
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07)
	Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
	DeviceName:  Onboard IGD    00:00.0 Host bridge [0600]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers [8086:191f] (rev 07)
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) [8086:1901] (rev 07)
00:02.0 VGA compatible controller [0300]: Intel Corporation HD Graphics 530 [8086:1912] (rev 06)
00:14.0 USB controller [0c03]: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller [8086:a12f] (rev 31)
00:16.0 Communication controller [0780]: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 [8086:a13a] (rev 31)
00:17.0 SATA controller [0106]: Intel Corporation Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode] [8086:a102] (rev 31)
00:1b.0 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #17 [8086:a167] (rev f1)
00:1b.2 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #19 [8086:a169] (rev f1)
00:1b.3 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #20 [8086:a16a] (rev f1)
00:1c.0 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #1 [8086:a110] (rev f1)
00:1c.4 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #5 [8086:a114] (rev f1)
00:1c.5 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #6 [8086:a115] (rev f1)
00:1c.6 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #7 [8086:a116] (rev f1)
00:1c.7 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #8 [8086:a117] (rev f1)
00:1d.0 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #9 [8086:a118] (rev f1)
00:1f.0 ISA bridge [0601]: Intel Corporation Z170 Chipset LPC/eSPI Controller [8086:a145] (rev 31)
00:1f.2 Memory controller [0580]: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller [8086:a121] (rev 31)
00:1f.3 Audio device [0403]: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller [8086:a170] (rev 31)
00:1f.4 SMBus [0c05]: Intel Corporation 100 Series/C230 Series Chipset Family SMBus [8086:a123] (rev 31)
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2) I219-V [8086:15b8] (rev 31)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP104 [GeForce GTX 1080] [10de:1b80] (rev a1)
01:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
05:00.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578]
06:00.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578]
06:01.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578]
06:02.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578]
06:04.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] [8086:1578]
09:00.0 USB controller [0c03]: Intel Corporation DSL6540 USB 3.1 Controller [Alpine Ridge] [8086:15b6]
0b:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
0c:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:0612] (rev 02)
	Subsystem: Gigabyte Technology Co., Ltd HD Graphics 530
	Kernel driver in use: i915
	Kernel modules: i915
00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd 100 Series/C230 Series Chipset Family MEI Controller
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode] (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode]
	Kernel driver in use: ahci
00:1b.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #17 (rev f1)
00:1b.2 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #19 (rev f1)
00:1b.3 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #20 (rev f1)
00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #1 (rev f1)
00:1c.4 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #6 (rev f1)
00:1c.6 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #7 (rev f1)
00:1c.7 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #8 (rev f1)
00:1d.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #9 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Z170 Chipset LPC/eSPI Controller (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd Z170 Chipset LPC/eSPI Controller
00:1f.2 Memory controller: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd 100 Series/C230 Series Chipset Family Power Management Controller
00:1f.3 Audio device: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd 100 Series/C230 Series Chipset Family HD Audio Controller
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:1f.4 SMBus: Intel Corporation 100 Series/C230 Series Chipset Family SMBus (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd 100 Series/C230 Series Chipset Family SMBus
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (2) I219-V (rev 31)
	Subsystem: Gigabyte Technology Co., Ltd Ethernet Connection (2) I219-V
	Kernel driver in use: e1000e
	Kernel modules: e1000e
01:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1080] (rev a1)
	Subsystem: PNY GP104 [GeForce GTX 1080]
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
	Subsystem: PNY GP104 High Definition Audio Controller
05:00.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015]
06:00.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015]
06:01.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015]
06:02.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015]
06:04.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015]
09:00.0 USB controller: Intel Corporation DSL6540 USB 3.1 Controller [Alpine Ridge]
	Subsystem: Device 2222:1111
0b:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
	Subsystem: Gigabyte Technology Co., Ltd I211 Gigabit Network Connection
	Kernel driver in use: igb
	Kernel modules: igb
0c:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
	Subsystem: ASMedia Technology Inc. ASM1062 Serial ATA Controller
Here is the lspci -nn
find /sys/kernel/iommu_groups/ -type l - did not turn up with any results.
I was able to configure the grub bootloader with the GPU and GPU audio, however I don’t remember using modprobe.
Can you post your grub config file?
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="apparmor=1 security=apparmor resume=UUID=79d10a0b-05c0-4e6d-bfbf-613635798ed6 udev.log_priority=3 quiet intel_iommu=on vfio-pci.ids=10de:1b80,10de:10f0"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command 'videoinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_COLOR_NORMAL="light-gray/black"
GRUB_COLOR_HIGHLIGHT="green/black"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/usr/share/grub/background.png"
#GRUB_THEME="/path/to/gfxtheme"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
/boot/grub/grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_gpt
insmod ext2
set root='hd3,gpt2'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,gpt2' --hint-bios=hd3,gpt2 --hint-efi=hd3,gpt2 --hint-baremetal=ahci3,gpt2  495d3598-750f-47bd-8f7e-2f4e6e1a120f
else
  search --no-floppy --fs-uuid --set=root 495d3598-750f-47bd-8f7e-2f4e6e1a120f
fi
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=en_US
  insmod gettext
fi
terminal_input console
terminal_output gfxterm
if [ x$feature_timeout_style = xy ] ; then
  set timeout_style=hidden
  set timeout=10
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 10 ; then
  set timeout=0
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-495d3598-750f-47bd-8f7e-2f4e6e1a120f' {
	savedefault
	load_video
	set gfxpayload=keep
	insmod gzio
	insmod part_gpt
	insmod ext2
	set root='hd3,gpt2'
	else
	fi
	linux	/boot/vmlinuz-5.6-x86_64 root=UUID=495d3598-750f-47bd-8f7e-2f4e6e1a120f rw  apparmor=1 security=apparmor resume=UUID=79d10a0b-05c0-4e6d-bfbf-613635798ed6 udev.log_priority=3 quiet intel_iommu=on vfio-pci.ids=10de:1b80,10de:10f0
	initrd	/boot/intel-ucode.img /boot/initramfs-5.6-x86_64.img
submenu 'Advanced options for Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-495d3598-750f-47bd-8f7e-2f4e6e1a120f' {
	menuentry 'Manjaro Linux (Kernel: 5.6.16-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.6.16-1-MANJARO x64-advanced-495d3598-750f-47bd-8f7e-2f4e6e1a120f' {
	savedefault
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd3,gpt2'
		else
		fi
	menuentry 'Manjaro Linux (Kernel: 5.6.16-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.6.16-1-MANJARO x64-fallback-495d3598-750f-47bd-8f7e-2f4e6e1a120f' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd3,gpt2'
		else
		fi
		initrd	/boot/initramfs-5.6-x86_64-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows Boot Manager (on /dev/sda1)' --class windows --class os $menuentry_id_option 'osprober-efi-AEDF-206F' {
	savedefault
	insmod part_gpt
	insmod fat
	set root='hd0,gpt1'
	  search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,gpt1' --hint-bios=hd0,gpt1 --hint-efi=hd0,gpt1 --hint-baremetal=ahci0,gpt1  AEDF-206F
	else
	  search --no-floppy --fs-uuid --set=root AEDF-206F
	fi
	chainloader /efi/Microsoft/Boot/bootmgfw.efi
set timeout_style=menu
if [ "${timeout}" = 0 ]; then
  set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/60_memtest86+ ###
if [ "${grub_platform}" == "pc" ]; then
    menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
        search --fs-uuid --no-floppy --set=root --hint-ieee1275='ieee1275//disk@0,gpt2' --hint-bios=hd3,gpt2 --hint-efi=hd3,gpt2 --hint-baremetal=ahci3,gpt2  495d3598-750f-47bd-8f7e-2f4e6e1a120f
        linux16 /boot/memtest86+/memtest.bin
fi
### END /etc/grub.d/60_memtest86+ ###
Strange, seems like even though you have enabled iommu with intel_iommu=on, it is not working on your system, evident by the fact that find /sys/kernel/iommu_groups/ -type l doesn’t return anything.
Since iommu isn’t active you are unable to isolate your gpu and can’t pass the hardware to the VM.
What tutorial have you been following? Also what specific motherboard do you have? Does it have an iommu option that you have to enable?
dmidecode -t 2
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: Z170X-UD5-CF
Hey, @Kinky_Flapjacks
The formatting of your post was edited for clarity, you can use backticks (``) to surround code to make it highlighted.
The youtube links have been fixed, and your user level has been bumped so you should be able to post other links as well.
As for your issue, have you run sudo grub-mkconfig -o /boot/grub/grub.cfg and then rebooted?
Thanks for the account update!
Unfortunately, when I ran that command sudo grub-mkconfig -o /boot/grub/grub.cfg , I was unable to load back onto the desktop after reboot. I was able to get to a terminal via Ctrl+Alt+F2, but it appears something got messed up with loading the display manager. I guess lucky for the dual boot? I’m also guessing there is something wrong with the Grub config.
Yah, you needed to run that and reboot before any of the changes in the grub config will take effect.
Perchance try removing the vfio-PCI.ids=id,id section from your grub config then re-running grub mkconfig command and rebooting.
