Hey all! I am attempting to create a Windows 10 Virtual Machine using virt-manager, but can’t pass my wifi card to my machine. This is an issue, as I need a Windows system and a mobile device on the same wireless network to test some software. When attempting to add my PCI hardware through the GUI menu, I am met with an error stating that the host doesn’t support passthrough of host devices. How can I fix this?
My lspci -k output:
00:00.0 Host bridge: Intel Corporation 8th Gen Core 4-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] (rev 07)
DeviceName: Onboard - Other
Subsystem: ASRock Incorporation Device 3e1f
Kernel driver in use: skl_uncore
Kernel modules: ie31200_edac
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 07)
Subsystem: ASRock Incorporation Device 1901
Kernel driver in use: pcieport
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
Subsystem: ASRock Incorporation Device a379
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
Subsystem: ASRock Incorporation Device a36d
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
Subsystem: ASRock Incorporation Device a36f
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
Subsystem: ASRock Incorporation Device a360
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Cannon Lake PCH SATA AHCI Controller (rev 10)
DeviceName: Onboard - SATA
Subsystem: ASRock Incorporation Device a352
Kernel driver in use: ahci
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #11 (rev f0)
Subsystem: ASRock Incorporation Device a332
00:1d.3 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #12 (rev f0)
Subsystem: ASRock Incorporation Device a333
00:1f.0 ISA bridge: Intel Corporation H370 Chipset LPC/eSPI Controller (rev 10)
Subsystem: ASRock Incorporation Device a304
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
DeviceName: Onboard - Sound
Subsystem: ASRock Incorporation Device 288a
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_cnl
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
Subsystem: ASRock Incorporation Device a323
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
Subsystem: ASRock Incorporation Device a324
Kernel driver in use: intel-spi
Kernel modules: intel_spi_pci
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7)
Subsystem: ASRock Incorporation Device 5001
Kernel driver in use: amdgpu
Kernel modules: amdgpu
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
Subsystem: ASRock Incorporation Device aae0
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: ASRock Incorporation Motherboard (one of many)
Kernel driver in use: r8169
Kernel modules: r8169
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
Subsystem: AzureWave Device 3043
Kernel driver in use: rtw_8821ce
Kernel modules: rtw88_8821ce
My lspci -nn output:
00:00.0 Host bridge [0600]: Intel Corporation 8th Gen Core 4-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] [8086:3e1f] (rev 07)
00:01.0 PCI bridge [0604]: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) [8086:1901] (rev 07)
00:12.0 Signal processing controller [1180]: Intel Corporation Cannon Lake PCH Thermal Controller [8086:a379] (rev 10)
00:14.0 USB controller [0c03]: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller [8086:a36d] (rev 10)
00:14.2 RAM memory [0500]: Intel Corporation Cannon Lake PCH Shared SRAM [8086:a36f] (rev 10)
00:16.0 Communication controller [0780]: Intel Corporation Cannon Lake PCH HECI Controller [8086:a360] (rev 10)
00:17.0 SATA controller [0106]: Intel Corporation Cannon Lake PCH SATA AHCI Controller [8086:a352] (rev 10)
00:1d.0 PCI bridge [0604]: Intel Corporation Cannon Lake PCH PCI Express Root Port #11 [8086:a332] (rev f0)
00:1d.3 PCI bridge [0604]: Intel Corporation Cannon Lake PCH PCI Express Root Port #12 [8086:a333] (rev f0)
00:1f.0 ISA bridge [0601]: Intel Corporation H370 Chipset LPC/eSPI Controller [8086:a304] (rev 10)
00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10)
00:1f.4 SMBus [0c05]: Intel Corporation Cannon Lake PCH SMBus Controller [8086:a323] (rev 10)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller [8086:a324] (rev 10)
01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] [1002:699f] (rev c7)
01:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] [1002:aae0]
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter [10ec:c821]
My grub.cfg file:
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos1'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 410846cc-9432-4b2b-92fe-55c5c565602b
else
search --no-floppy --fs-uuid --set=root 410846cc-9432-4b2b-92fe-55c5c565602b
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_US
insmod gettext
fi
terminal_input console
terminal_output gfxterm
insmod part_msdos
insmod ext2
else
fi
insmod gfxmenu
loadfont ($root)/boot/grub/themes/EndeavourOS/unifont-regular-16.pf2
insmod png
set theme=($root)/boot/grub/themes/EndeavourOS/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
set timeout=5
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'EndeavourOS, on linux-zen' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-zen-advanced-410846cc-9432-4b2b-92fe-55c5c565602b' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading kernel linux-zen ...'
linux /boot/vmlinuz-linux-zen root=UUID=410846cc-9432-4b2b-92fe-55c5c565602b rw resume=UUID=c96fd141-6fba-4e51-901b-5e3e734d6486 loglevel=3 nowatchdog nvme_load=YES
echo 'Loading initial ramdisk ...'
initrd /boot/intel-ucode.img /boot/initramfs-linux-zen.img
menuentry 'EndeavourOS, on linux-zen (fallback initramfs)' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-zen-fallback-410846cc-9432-4b2b-92fe-55c5c565602b' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
initrd /boot/intel-ucode.img /boot/initramfs-linux-zen-fallback.img
menuentry 'EndeavourOS, on linux' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-advanced-410846cc-9432-4b2b-92fe-55c5c565602b' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading kernel linux ...'
linux /boot/vmlinuz-linux root=UUID=410846cc-9432-4b2b-92fe-55c5c565602b rw resume=UUID=c96fd141-6fba-4e51-901b-5e3e734d6486 loglevel=3 nowatchdog nvme_load=YES
initrd /boot/intel-ucode.img /boot/initramfs-linux.img
menuentry 'EndeavourOS, on linux (fallback initramfs)' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-fallback-410846cc-9432-4b2b-92fe-55c5c565602b' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
initrd /boot/intel-ucode.img /boot/initramfs-linux-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg
fi
### END /etc/grub.d/41_custom ###
Any help would be greatly appreciated. Thanks in advance!
