PCI (not PCIe) SAS HBA or RAID that works with Linux
Anybody know of a 32-Bit PCI (not PCI-e) SAS controller that exists? It can be just an HBA or a RAID card, just as long as it works in a semi-recent version of Linux (Xubuntu 22.04).
Tried looking around but no search engine can differentiate between PCI and PCI(e).
Thanks.
I’ve got an LSI SAS3041 with a PCI-X length slot, but it is backwards compatible with 32 bit PCI. Just make sure nothing on the motherboard will psychically obstruct a longer card. Works with Linux, Windows, and OSX versions as old as anyone is likely to want :laughing:
Thank you for the info. I will look into that unit.
It appears the card is keyed for 3.3V and unfortunately my motherboard is 5V. All the PCI-X SAS cards I could find were 3.3V.
The reason I was looking for a PCI SAS Controller is I have a bunch of SAS hard drives and was hoping to put them to use in an old system. I guess I’ll just get some SATA drives for this project instead. SAS looks like it became more popular after PCIe was around and SCSI was in during the PCI era.
Again, thanks for the info.
I dunno how old this system is, but would a Raspberry Pi suffice? It supports PCIe on some models and that lets you use SAS cards.
But you could also try PCIe to PCI adapters. I think those would do much better in that older system if you could fit a right-angle riser or mount the SAS card in a weird spot.
What’d you end up going with?
