Pc won't turn on!
So heres my system:
AMD FX 6300
8gb G Skill Sniper series 1866
GTX 760
Asus M5A78l-m
Corsair CX500
WD 1tb HDD Salvaged Optical drive
So i just put this together, and i think its the processor and the motherboard. I think its the version of the bios, but my computer will not turn on. Any thing i can do to fix this? I can't afford to replace theses.
I know my friend bought a AM3+ motherboard that did not support his FX processor so he bought a cheap $30 athlon and updated the bios and swapped out the CPU to the FX. All was well after this.
I'd check your ram. Does it boot to BIOS at least? If it does I'd load up Parted Magic and run a Mem Test.
If not, pull all the ram sticks out and test them individually (put the stick in, test for boot) and repeat until you've tested them all. If it doesn't boot, I got nothin' for ya.
That board has a 760g northbridge which is a Vista era part. This board was made more for Athlon IIs and Phenoms.
If the board isn't turning on then it's going to be an issue with power delivery. If it's turning on but not POSTing then it could be a BIOS issue or your components aren't seated properly.
Make sure everything is plugged in all the way, if you're getting multiple beeps re-seat your RAM and GPU. If that's not working then install a BIOS update onto a flash drive and use the EZ flash update to fix.
Well, it should at least try to turn on even if the power delivery is kind of sad.  It should work for at least a couple seconds, lol.
Test the RAM.  Try different slots, different sticks in different slots, etc.
Do fans turn on when you click the power button?  Check your front I/O?
