So I took apart all of my pc cleaned up the fans n everything and left it overnight to dry in morning put iy all back together pushed the power on button on the mobo and it doesn't boot at all I checked the socket pins none of them bent checked everything on mobo all is fine and gpu atmom ive no idea what could be the problem
My specs are
P5q-e mobo
Intel core 2 quad q6600
4870 amd
4gb ddr 2 ram
Kingston hyper x 3k 120gb ssd
500gb old hdd
I tried only connecting 1 hdd/ssd didint work either
You washed it with what... If it was a liquid.. congratulations you are the worlds biggest imbecile and good luck building a new PC because you've most likely broken everything. Also what anti-static precausions did you take?.. I'm assuming none. I think in this case it's most likely you destroyed something or everything.
As for testing I put only cpu+heat sink in but forgot to plug heat sink in it booted but I quickly unplugged power cuz I though chip would burn without heatsink than plugged in heatsink and tried to boot didint boot tried putting everything no boot so no idea atmom seems like CPU is dead if im right? As for psu im sure its working considering mobo led lights up
edit Thanks for all the hell although im not sure what but reputting everything together n blowin some holes made it boot Thanks for all the help again
I did that good few times today last time said fuck it went on lappy watched movies than said fuck it leme try again pluged power pressed boot n worked like magic wondering what changed though over time I was watching movie
Yeah all good you got it up and running again. But for future reference never ever mention you let a PC components out to "DRY". It fucks with our brains as if the fabric of the universe changed and turned Beer into Wine.......Yuk.
