When i was playing some War thunder today my PC suddenly crashed, no biggie i thought, it happens more often. The screen it ahd when crashing was a black screen with white vertical lines. I tried to power it on but i couldnt. So i tried changing the power cord, plugging it in another outlet but to no avail.
I took my system apart, removed the gfx card, pci lan cards, replaced the huge cooler with the stock one and tried again. Nothing, what about with other sticks of ram? nothing.
I tested the power supply, it worked. (i bridged the green line with a black one, a fan i connected turned on).
But still when connecting it to the mobo nothing worked, started spinning etc.
I bridged the power supply pins and it still wouldnt work.
Does anyone have something i could try or does anyone know what is broken?
i would look into the cause aswell, like a surge, or your psu not being too voltage stable. dont wanna a blow another board. espicially if its not the boards fault for being blown
unfortunately not, you could always invest in surge protected sockets and a ups. the only way to tell really is if you noticed your lights flickering/dimming and or your monitor doing the same while using your pc, theese are also sympotoms of white/blackouts. but they wont always show when it happens.
