PC will not start up
these are the specs http://pcpartpicker.com/user/zoura20/saved/1p3N when i press the power button only a blue light appears in the motherboard but nothing else i dont know what it is i tried changeing the front panle conectors but nothing still
Good afternoon
We need a little more then that were you doing a build did you change a part did it work before even an image of it with the side panel off
Mistress
no i simply only put all the parts together and changed the front panel conectors from the mother board
why did you open a new topic when you had the other one where you were being helped?
